I have a newly installed Hearthstone Homestead woodstove and am struggling with smoke piling out when loading, as well as low burn temps.
Here is some background:
It is installed in our family room, main floor, in a 1988 house that is very well insulated (8" walls/Andersen Windows). The chimney comes vertical out of the stove, then turns a 45° angle, then a 90° (to go outside), then another 90° (to go vertical), then (2) 45° angles to get around the eave of the roof. The outside sections are Metalbestos and the inside sections are double-wall. The overall height is good, as it carries up past the second story of the house, then another 8' or so past the edge of the roof. I know it is good to the rule of thumb about the distance to the nearest obstruction, etc. but have not measured the overall height. The stove and chimney were professionally installed.
I have been lighting fires in it for a week or so and have never struggled so bad to get/keep them going in my past! I have burned wood for many years using standard iron woodstoves as well as a catalytic Fireplace Xtroidinaire (loved it!) so I am comfortable with using wood. The wood I am currently using is old dry cherry, ash, and maple, if anything it may verge on the 'too-old' side not too green. I have been careful not to use any punky stuff to make sure that is not an issue.
I think I am fighting a chimney draft issue but would like some input/advice. I leave the door on the stove cracked to try and get a good rolling fire going but even that seems to have a more minimal effect than I would expect. I do not get smoke pouring out as long as the door is only open 1-2 inches but beyond that here she comes! We have a Chimgard stove thermometer installed in the chimney just above the stove outlet and I think I have seen in touch 350° once or twice but that is it. My manual states the surface temp on the stove can get to 600° before overfiring, how does that correlate to the chimney temp? The stove will draft properly when the temp on the dial is at 250-300° or so (and not smoke in the house with the door open), but it is very hard to get it there and keep it there, so it smokes a lot in the meantime trying to tend the fire. The air supply is wide open, I have cracked a door or window to make sure we are feeding enough input air, but none of this seems to matter much. It just seems to me like the fire is not getting enough air to really get going. Once I do get a good bed of coals it is very easy to draw it back down by placing a single split piece on the bed, so I am forever fighting adding wood but trying to not kill the fire.
Help! I love the stove, it heats the house nice and has a great even heat level, but I don't have time to fiddle with any fire I start for the first 1-2 hours to try and get a large batch of coals going. I expect to tend it but shouldn't have to leave the door open for the first hour or two.
