GrumpyDad
I dont know what is inside the dauntless but this brochure statement would suggest there are some sort of thermostatic controls.My Duantless doesnt have a bi-metal flap controller. The air control lever on the right side controls a flap on the lowest rear part of the stove (where the external fresh air pipe mount goes). That's it.
If these stoves used to come with a bi-metal thermastatic control, it was removed in production in my version.
THERMOSTATICALLY CONTROLLED COMBUSTION
Our unique, built-in thermostat requires no electricity and automatically adjusts the required air for combustion. Just set the stove for the heat output you want and let the thermostat do the rest. The result—longer, more even heat.
Continuous Combustion Controltm (C3)Our exclusive C3 technology is tuned to provide optimal burn throughout the life of your fire. From startup to last coals, C3technology manages all the give-and-take for you, automatically adjusting and delivering just the right amount of air to optimize efficiency and heat output. This heat activated technology requires no electricity or manual air controls. The result – the most consistent, easiest burn you will experience.
I have to laugh at that last statement a bit. If they consider the dauntless easy, Id hate to see hard.
I do hear some tinking sound from time to time as the stove is operating. There's a different sound when it's really getting hot but that's likely expansion/contraction sounds. The tinking sound will be often from time to time and it sounds like something is happening inside the stove but I dont know what.
![[Hearth.com] 2023/24 VC owners thread general discussion [Hearth.com] 2023/24 VC owners thread general discussion](https://www.hearth.com/talk/data/attachments/319/319554-cb04a4540c256db1957899568e17df29.jpg?hash=jfW3cYeQyV)
