arnermd
-12 F here this morning.... Stove can't keep up, time to put on a sweater. Glass is clean after 24 hours of burning hard.... Thermostats still off.
-11 here. Had my heat on yesterday too. Went snowboarding and couldn't feed the stove to run it hot.-12 F here this morning.... Stove can't keep up, time to put on a sweater. Glass is clean after 24 hours of burning hard.... Thermostats still off.
That picture was after tossing 2 splits in.THANK YOU!
This is an example of the 'orange glow' that I refer to when I say you should always run your stove to the point that you see flames UNLESS you see this!
This is exactly what Im talking about. So much satisfaction as I keep forgetting to get a picture.
Is there more wood in there above the glow line or is this toward the last 1/3 of the burn time for this load?
The GrumpyDad glowTHANK YOU!
I have wondered.... but the answer seems to be an easy one..... it comes out the back of the stove. Some of it goes up the chimney, as I do see a rise in flue gas temps when I get the cat that hot.@arnermd Did you ever wonder, where does all of that heat from the cat go? At 1500-1600 at the cat the flue temps don't get high but neither do the stove temps.
Not sure where you are going with that..... Draft sets the flow so I am struggling to understand the point, no offense.Good answer but...If air flow was that slow draft would make the gas flow faster and cool things.
Used one of these for years. http://www.bearmountaindesign.com Well worth the $70.Did such a good job of running my stove last night that a pipe froze and burst on the other side of the house. Still waiting on the plumber to get here. Already shut off that zone and drained the line.
It doesn't get as cold here but when it gets to zero or single digits I turn the thermostat up as high as it will go, the stove is close to the thermostat. It will run the heat and keep the pipes from freezing and warm the outer rooms.Did such a good job of running my stove last night that a pipe froze and burst on the other side of the house. Still waiting on the plumber to get here. Already shut off that zone and drained the line.
In theory the air control sets the flow, these things are supposed to be "air tight".Not sure where you are going with that..... Draft sets the flow so I am struggling to understand the point, no offense.
More draft = more airflow (all else being equal) and hence faster combustion rates, higher heat flux and hence higher temps.
This is what I do. Or else my thermostat would never click on and the outer rooms would freezeIt doesn't get as cold here but when it gets to zero or single digits I turn the thermostat up as high as it will go, the stove is close to the thermostat. It will run the heat and keep the pipes from freezing and warm the outer rooms.
I think the low Friday night was something like -15 or something wild like that. Plumbers found at least 2 bursts in the pipe. They capped off both ends and said that they had to wait for it to thaw before they were able to fix it. For the next couple days I’m down a heat zone so the stove it is.It doesn't get as cold here but when it gets to zero or single digits I turn the thermostat up as high as it will go, the stove is close to the thermostat. It will run the heat and keep the pipes from freezing and warm the outer rooms.
My home is on a crawlspace that has vents, the vents close when it's cold but it still gets cold under there. I have forced hot air with ducts down there so even with the stove in the room with the thermostat I can turn the heat to 80* and the furnace puts some heat under there. It won't run long as it doesn't take much to raise the room with the thermostat and stove but it's enough to keep everything warm enough.I think the low Friday night was something like -15 or something wild like that. Plumbers found at least 2 bursts in the pipe. They capped off both ends and said that they had to wait for it to thaw before they were able to fix it. For the next couple days I’m down a heat zone so the stove it is.
My big issue is that the stove is in the same room as the thermostat. The stove room might be 75 but the outer rooms are obviously much colder. Also this happed in a bay window that doesn’t have basement below it so there wasn’t that protection of a 60 degree basement to keep the pipe warm.
I would agree about the draft. With lower draft the hot gasses linger in the cat chamber and run hot. We are adding two more feet to test this theory. Seems like a draft needy stove.Data from the cold snap, (Friday - Sunday)
Stove burned really well went it got cold, notice peaks all <1300 during the cold streak. Before and after the cold snap I was seeing my usual peaks at 1600.
Key damper was full open for the entire time.
What was different?
Installed the metal cat today.... first burn coming up.
- I ran with a bit more air, 50%- 75% when it was cold. Stove temps were 450 - 600. Hotter than I have been running.
- Maybe my stove like to run with more primary air and hotter STT?
- I also did some hot reloads where I added a few spilts when the cat was >800
- Obviously it was cold and thus more draft
- Is it even possible my cure is more draft? Not less as I have been pursuing? Seems hard to believe.
Those look good, how much do they cost? Does the finish match the stove well?Shelves finally came in. Only 6 months of waiting. Definitely helps fill the space more
Spot on match. 10 minute install. They weren't cheap. I'd have to check the invoice but I think they were about 300 per shelfThose look good, how much do they cost? Does the finish match the stove well?
Thanks $300ea is comical but would be nice for a steamer so you can still load from the top.Spot on match. 10 minute install. They weren't cheap. I'd have to check the invoice but I think they were about 300 per shelf
After I closed the bypassed damper air was at 100%@arnermd When did you move the air to 50%? Did you leave it at 50% for the whole burn? What caused the small spike at 4AM?
