spudman99
So I have a question for the masses:
My princess insert is now on its 3rd season. I have done nothing to it other than to lube the thermostat and blow clean the fan. It has not required any maintenance. My door closes normally but there is very little resistance on the handle when I lock it down on the latch. Like I can close it with 2 fingers and a push. I don't have any smoke odor, however that may be due to my high draft. I installed a key damper in Nov, now my Magnehellic reads 0.18 on high burn instead of 0.21wc. No way possible to get it into the desired spec (at least not this year).
Is this type of tension on the door handle and latch typical? After 3 years shouldn't I have to tighten the latch nut a bit?
Not looking for an answer to a non-problem, just leaning on your experience. TIA
