Puposky
Hello all,
First time posting but used this site a lot and it helped in my decision to get a blaze king princess last year. Do not regret my decision but my cat appears to be not working if I turn it much below a medium burn. It takes quite a while to kick out but i am not getting the burn times and it shows it in the inactive zone when there is a 1/4 of the wood left. Last year, until the very end, I would get hours more in the active zone with that amount left. At the end of last year I was getting a little suspicious of this as well. I also am seeing more smoke than usual, once I engage the bypass I always have a bit of smoke coming out, where as last year, until the end I had none.
I did a gasket check and it was pretty easy to pull a dollar bill thru one spot between the hinges, I was never really impressed by the factory installation of the gasket seemed a bit slapped in. Admittedly on two occasions I opened the door before I disengaged the bypass. A big no no I understand but too used to my old stove I guess. Both times the stove was already out of the active zone but… that may have been my undoing?
I ordered a new gasket thru hecklers and some high temp silicone, but read here that I should only get an oem gasket. Hecklers states it is for a blaze king princess, should I not use it? Also, is high temp silicone ok? Appreciate any advice
Thanks
Thanks
![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284547-906e15accf45abee2f9b6d82031e5d99.jpg?hash=W077tQVLZR)
![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284548-69238c0273c5d4905a35640d8dcaf3ff.jpg?hash=yXjHrSzMWH)
![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284549-509e9d08d930f34d9d74fe30e39e944d.jpg?hash=KFIxCQdlK8)
![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284550-ab2abde21f26c7fc61cab0c1476f3b3d.jpg?hash=91G4vT8Z2f)
![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284552-b2ff5bfbaa6dc1f2b4b906cba3395b6a.jpg?hash=kx5OYSp8EI)
