It is ugly as hell though lol. If I ever do buy a bk it will absolutely never be a king or princess. They do have others that look good though
I screwed up my woodstove operation yesterday- I was letting the stove warm up a little on high after a couple days of burning real low- and forgot about it, and went to work with the stove full of oak on wide open throttle.
Because it's a BK, this story ends with "everything was ok because the thermostat is awesome like that", but I still feel pretty dumb. Imagine if it was one of my old stoves I just left with the air wide open... I'd be posting "does this look warped to you?" instead.
Moral of the story: Take care of your gaskets, and your thermostat will take care of you. (Or possibly "don't operate a wood stove if you have no short term memory", but I like the first one better.)
Thanks again, BK!
After using the Princess for one season, I have zero negative comments. I bought the stove 100% based on the positive comments here. It is not a blast furnace, but low and slow performer.
First, I think all manufacturers should be given the opportunity to make it right. Call the dealer and ask who the local company rep is and go that route.Looking for a bit of advice (especially since BKVP is on here) regarding a new Blaze King stove.
Short background: Current Harman TL-300 owner. Starting to form cracks on the top load opening after 8 years of use. VERY careful to never over fire. Harman/local dealer is all crickets when calling in the 10 year firebox warranty. Still waiting to hear back. Either way, I'm done with this stove. WAY too temperamental to keep happy.
We have a 2400 square foot fairly modern home. Stove is located centrally on the first floor, not basement. 19' of triple wall stainless 6" chimney straight up, with a 2' 45 bend in the double wall stove pipe. In New England (north central MA), so we win the lottery on temp variation during the year. Current Harman has no issue keeping the house nice even during the -10's. Burning all hardwood. 4" outside air kit already installed.
I was looking at a Princess Ultra (quoted $3099) with convection deck ($?), fan kit ($300), and outside air kit ($150).
Would it be worth considering the King Ultra as well? From what I've read here, my setup is nearly perfect if using a King on a 6" flue with a reducer.
With a less labor intensive stove, I'd be looking to burn more often than I currently have been. Babysitting the stove for 2-3 hours before trying to get it to burn on it's own for 4 means I haven't burned as much as I'd like. Hoping a new stove will change that. Will the larger firebox be worthwhile to get it to burn for longer times? Since the convection top is included on the King Ultra, I'm wondering what the actual price difference would end up being vs buying the Princess with the convection deck.
Advice welcome.
So had you engaged the cat or did you blow a whole load of oak at full throttle through the bypass? Have you checked the gasket retainers for failure?
Second, you can see how face melting, high Btu's can present challenges. In your case, you may not even know your stove over fired. Even if you did your part, stack effect at 1:00 a.m. with a manual air control, an over fire can happen. Even if the air control was shut down.
When the stack effect increases, the opening of air inlet may not change, but the cm sure does! I've seen extremely well built stove glow bright orange at -40F in Alaska! And the air control was on low.
Back to your question, the guys here are correct. Do not try to run a King on 6"....your house will fill with smoke and neighborhood dogs will chase your beef jerky smelling carcass.
Princess is probably best based on your OP.
BKVP
Lol, I have a buddy with an old drolet whose house smells like smoke all the time and my dogs love him,your house will fill with smoke and neighborhood dogs will chase your beef jerky smelling carcass
BKVP
It's been 25 days since they saw the cracks, denied the warranty, then I sent them their own warranty statement from their website (stating firebox is 10 year warranty), then "We'll get back to you". Checked in twice since, still "working on it". I need something to heat my house very soon. We're into the 20's at night. If they make it right, they will either fix the stove, replace the stove, or compensate me in some way to replacing the stove. No matter the situation, I'm ready to move on to something more reliable.
Princess it is then. Now to just call back all my local dealers to make sure their quoted prices are for the Ultra.
The Ultra, Classic and Parlor are ALL available in the the Princess 32 model.You are right on the edge of the old model princess being out of production. Replaced by the new 2020 princess that has much better emissions specifications and is not available as an ultra/classic/parlor. Check that your dealer actually has what you want.
So my Princess Insert is now installed and I have 1 week under my belt. Can someone here please hold my hand
I think I have the loading process figured out, and am burning 2 year old split cherry that is around 18%. No problem with wood and I have not had less than a 12 hour burn using my settings. I have not pushed the unit because I am worried about an overfire, creating a dangerous situation or just simply creating too much heat that will burn the house down. Basically I'm still like a kid in school learning about this unit.
After I load and begin to char the wood, the flames fill the firebox, numerous ones which lap over the flame screen. Is that ok, or am I potentially damaging the combustor with direct fire?
After the cat goes active (which is easy), I see no glow at all. I think I saw one time the right side slightly yellow, but otherwise there is no glow from the cat. I know its working as there is no smoke outside, the cat thermo is pegged and unit functions fine I guess?
Yesterday I had to go out and left the insert after a reload on medium on the thermo. I realize every unit is different, in this case my son texts me 2 hours later that the top of the insert was 600deg with the fan on med. That is the highest it has been, I have not let the top get much above 475 or so for fear of creating a fire (see worries above). What is a safe upper level temperature on the top of the Princess insert if anyone has a reference point.
If I run the box on high and fill it with flames and let that go for any length of time, am I again at risk of damaging the firebox or the liner or the appliance connector or the electronics in the fan section if the insert gets really hot?
If I run the fan on low, high or in between, but basically all the time, am I at risk of wearing it out within say a couple of years?
I suspect that I am just crawling with the operation of the insert, hold my hand and teach me Master BK'rs.
You do not need to worry about flame impingement on your bk. Flame on.So my Princess Insert is now installed and I have 1 week under my belt. Can someone here please hold my hand
The measurements should be at wide open on the tstat. If you close the tstat the pressure will increase giving you high reading but is not accurate.Thanks all for the hand holding. Baby steps but they are all important. I have no smoke smell at all...none... zippo..
Today I added some side insulation in the fireplace and connected my magnehelic. I did not add a key damper during the initial installation based on some advise here, but I wanted to for ease when everything was open. Hooked the unit up today and here are some following stats.
Initial reading, no fire, insert door open, bypass open a few hot coals. Reading is 0.05
View attachment 250961 View attachment 250963
2nd picture is with bypass open, wood fully engulfed with fire, charring the load. Once the cat is active, I close the bypass and continue on high.
View attachment 250964 View attachment 250965
1st picture is the reading with thermostat turned to medium, fire starting to die down. Clearly my draft is out of BK spec running this way. Not shown, but now the fire is gone, themo is at 1 tick above low, draft is at 0.17 inches wc. Again, should I be worried or am I running with too much draft that diminishes performance?
When the tstat is closed it will read higher. You want to know the reading when on high with a good fire going. That is what is important.My wife asked me if more inches were good or bad? I told her that was for the man-ehlic gauge....hehe.
Currently running on low, ITT (insert top temperature) is at 475, gauge reads .10 in. Guess that is good. Gonna be 62 deg tomorrow so I'll let it go out and check the door gaskets.
But before the thermostat starts to auto close due to over temp?When the tstat is closed it will read higher. You want to know the reading when on high with a good fire going. That is what is important.
That's correct. Being at 6 o'clock it delays the closing of the tstat cause it is keeping it open longer.But before the thermostat starts to auto close due to over temp?
No..After nearing the 10,000 hour mark I noticed my ceramic cat was a little sluggish, and stalling out on my overnight burns. Put the new one in yesterday. I forgot how fast it can climb into the active zone. Anyone have any numbers on how much efficiency or burn time/consumption a worn out cat is responsible for?
