I think your spoofing everyone anyway, No one trades in a BK for a Home Depot Stove
I think I'm done with the princess, these cats are a pain in the butt.
I ordered a new cat during the weekend, just received it in the mail, the company sent the wrong one, we're suppose to have a major storm here in 2 days followed up by some pretty rough arctic air, well I'm between a rock and a hard place here, a position that I don't like being in and I refuse to be in, so rather then wait a 2 weeks (turn around time, the company wont ship the new proper sized cat until they receive the other one sent in error back) I'll be going to HD and buying a nc30, (I know it can do the heating job)
So craigslist the princess goes. Good luck BK'ers it was a fun 4.5 seasons.
Mild weather. 24 hour burns. My wife and I went to a local stove store to look at furniture. She bought a chair. I checked out the stoves. Not a one in the store can actually provide usable heat then relight, cat active, after 24 hours.
Bummer, Kenny! The old cat can't get you thru the next few days? What happened to it?I think I'm done with the princess, these cats are a pain in the butt.
Burn time is a very ambiguous thing.
This is a huge bummer. Even the old Buck smoke dragons had an automatic thermostat that when up to temp... it kicked on. Wish they would add the feature or a way for homeowners to modify it.
I get it and understand it. But for many burners as the room temperature starts to drop it is time to reload. That would be the def. of burn time for them.
If you do the NC30, you know you're going to be itching to get back to the Princess after a season without it, right?
So how many stand alone stoves can compete with BK Kings or Princesses I’m burn time?
Sometimes when your heat demand is very high you’ve got to do that near the end. Coal buildup becomes a problem right about the same time.
View attachment 238545 View attachment 238546
Last post here for a little while, I need a break from this, actually feel a little emotional over this whole issue, but stubborn also.
Its a la crosse technology weather station (I think BJ's or Costco) theres a whole bunch of sensors you can mount anywhere and they all talk to the main data point which is wifi capableI know you said last post but what app and such is that?
Lopi Rockport
Blaze King Ashford 25
Then the stove, regardless which brand is can not be blame, or was underside for the job or what you need is to take care of others situations like leaking house, insulation etc, or whatever is happening. Some get disappointed with blaze Kings cause all what they have in mind is what other say about long burn times, and many want to achieve them when is real cold outside and they need to run it hard to keep up. I can run only one and handle my heat demand for the most part and the type of winters I have here, but just at times I will have to run it hard and possibly 3 reloads a day minimum.I get it and understand it. But for many burners as the room temperature starts to drop it is time to reload. That would be the def. of burn time for them.
My Princess heats my 1100 ft. perfectly. I do not expect it to heat my upper level of 1100 ft. I sized it accordingly thanks to this thread. Thank you all.
But as beholler said while back, when it gets damn cold the BK becomes just another steel box where you throw splits in to keep warm.
To me comparing burn times between a bk turned down low vs a tube stove turned down low is pointless. Because the btu output is drastically different. And I only need that low output maybe a week out of the year. The rest of the time I have been getting similar burn times.None so long as you’re talking about low output settings which is where those maximum burn times happen.
Don’t fall into that silly trap of comparing the bk burn time when it’s cranked up high to the maximum possible burn time of a noncat cranked down as low as it can go.
Woodstock cat stoves, and even the hybrids, are pretty dang close though.
Well saidI can really heat up the flue with the bk on high, it doesn’t seem to burn as cleanly either. Yes, I do believe that a properly sized bk is one that can run mostly at 50% or less of max with burn times over 12 hours. Once you set the stat much higher higher than that I believe that the performance advantage is too small to justify the drawbacks.
My 2012 princess has a fan system from bk that turns off and on with temperature automatically. New models lost that feature.
