It’s ugly, and the entire bypass system is identical. The original wasn’t though, but they changed that to help prevent cat failure.And it is a hybrid. It isn't ugly as hell . And I believe it has lower emissions. But it's the same size so that makes it an exact replica right?
No it is plain and boring but not visually unbalance. Yes the way the mechanism works is the same as the king. Which is the same way that Dutch West did theirs. But the specifics of the mechanisms are totally different.It’s ugly, and the entire bypass system is identical. The original wasn’t though, but they changed that to help prevent cat failure.
Thanks...Bogart's version great but Blazing Saddles was superb.If I could find a plate-steel stove that did what I wanted for 2/3 the price, I would go that route instead.
It's a definite possibility...lotta stoves out there. Live and read and learn.
Wholly cow, 4.42 cu.ft. box??! Is that legit, or is that like the Buck 91 "4.4" that, when I measured it, turned out to be about 3 cu.ft. usable?EPA is calling the 5100 top end 42K BTU/hr, about like your 3100.
Loads E-W or N-S..nice.
Classic movie line, well-adapted to sox. Well-played.![]()
We don't need no stinking sox, but we're gonna need a chitload o' dimes.Thanks...Bogart's version great but Blazing Saddles was superb.
I think you get a pair with each pair of BK stoves you order from the factory. Just order up two Ashfords!WTH! I need to know where to get those socks! I’ve got all kinds of funky socks.. need to add to my collection!!
I wish my home was poorly insulated, that would be an enormous improvement. I have zero insulation in the main part of this house, I'm still looking for a way to stuff insulation into solid stone.there were a couple of post pertaining to poorly insulated homes out there, I think Ashfull was responsible for a few of them.
Is your 3100 a tub reburn only or a hybrid, I was looking them up yesterday, classic 3100 and 3100 pro.The king is a plate steel stove. But regardless I have the 3100 that will be going back in next year.
Yes the 5100 is a monster of a stove not huge heatoutput but it does it allot longer than the 3100
No the 3100 is a tubestoveIs your 3100 a tub reburn only or a hybrid, I was looking them up yesterday, classic 3100 and 3100 pro.
Ahh never mind, see you posted hybrid.
They have come up with a new kind of artificially modified wood that is flat on all four sides and the same thickness all the way down its length! What you can do is nail down one length of this stuff, then nail some more pieces to that piece at 90 degree angles, and another parallel piece along the top. Some researchers have theorized that soon it will be possible to easily make all the spaces in between the vertical flatwoods the same with a new kind of stick that has regular markings on it- which will be important, because one could in theory make the spaces all the same size as a roll of insulation!
Flatwood is the future!
If you're like some of the kool-aide-drinkin' hole-riders here,you've only burned one brand of cat stove. My first stove after the Englander smoke-blower was the Dutchwest 2460, then the Woodstocks, and the Buck 91 at my MIL's, 1905 house with no wall insulation, 9.5' ceilings and stove room at one end of the house. All cat stoves. So even though I've never run a BK, I'm used to how cat stoves operate, and am not as wowed by their performance as the first-timers here seem to be. Ford, indeed.
That's right, all stoves involve trade-offs, and that's been my point all along.
BTW, I've been to the base of the Sangre de Cristos...but that was in September.
Weird stuff supposedly happens in that area...ever experienced anything like that?![]()
I've already got green wood..I think it's moss or mold or fungus or something.Santa Claus is not even gona drop you off green wood.
I just want to report, because others have mentioned it, that the BK Princess Insert is actually easier to control with the fan knob than the stat.
I understand the concept of why that would be once you understand how the stat works.
So for me, the process is load the stove, let char up a bit, turn stat way down, use fan to control heat output.
Works like a charm, the stat will adjust to compensate for the increased air speed.
Anyone else operating this way?
I treat the t’stat knob as my “coarse control”, and the fan knob as my “fine control”.
I do have that on one of my setups for long time and it work like champ.i am going to wire a temperature activated switch (a stat) for the fan that is across the room. temp gets below 70? fans kick on. like a furnace or any other HVAC product.
