I think everyone is missing the obvious response to the last two pages of banter: bholler needs a King!That Blaze Kings are better than other stoves if they are properly sized?
I have complimented the stove many times on what it is good at.You could give him a King and move his house to Alaska and he still wouldn't be able to compliment the stove without choking. In private, though... I bet that Princess is full of lip marks!![]()
Thermal degradation and thermal shock both terms the manufacturers and EPA use to define combustor failure. In the past 20 years, Corning, Sud Chemie, Clariant and Applied Ceramics have stated, air leaks can cause thermal shock and lead to combustor failure.
Not brutal cold at all 20s and 30s. Normally we have a longer shoulder season. But this year it went from 60s and 70s to 30s in a week. Then back up to 60s. It was really anoying.Are you kidding. I’m not sure where exactly in central Pa Bholler lives but from his description of the crazy short (2 weeks!) shoulder season and the amount of btu’s required to heat his house, I would think Alaska to be nothing more than a break from the brutal weather for him.
And to think, it isn’t even winter yet!![]()
So degradation of the wash coat do to an air leak is considered thermal shock?
If so, this would make steel cats no less susceptible to thermal shock by definition than ceramic. In fact, thermal shock would be the leading cause of death in steel cats!
Thermal degradation applies to the substrate in stove speak... But you are correct in the fact that once a cat hits 1600F repeatedly, the wash coat flattens out, loses surface area, becomes less effective and degrades in it's ability to effectively reduce (convert) particulates. Both substrates can degrade as well. Ceramic crack, chip and fall apart and stainless can warp and distort. That is why upper limits on cat temps need to be restricted in cat stove design.
I know it still needs lots of work. And we are on top of a ridge in the mountains so we have near constant wind. That is what causes the most problems. And thank you for not simply dismissing my experiences as bk hating nosense.Outside temps are in the 20’s and 30’s, yet you’re reloading a ~3cuft stove 3 times a day to keep a 2,200 sq ft home at 70*.
Most folks debating you can easily relate to those outside temps.
Most are heating comparitable sized spaces. At least enough so that they comprehend that amount of space and what it would take to heat it in there situation.
Ofcourse, comparable stoves.
Yet while they are in set in and forget it mode, reloading every 12 to 24 hours you are pitching wood into that steel box every 8 hours and wondering, what’s the big deal about this magic stove?
I know you upgraded your insulation but I really think your house is just still to leaky for you to reap the benefits of a cat stove and that’s also what many folks debating you are missing. There experience and yours will be totally different because your home is simply not very well insulated. It doesn’t make your experience wrong or there experience wrong, just different circumstances = different outcome.
Someone took out a BK Princess? Blasphemous stuff right there! Enjoy those overnight reloads is all I can say...
You do realize there are plenty of other stoves out there that can easily burn overnight dont you?
I'm doing it pretty easily with a firebox half the size of his Princess.
Not trolling, just pointing out that I get an overnight burn with a much smaller fire box. And even on middling woods like Black Cherry, the stove top is still over 250, not "waking up to a few coals."That troll bridge wood burns (naughty word)hot, huh?
Right, so you cut down the amount of wood gassing and weren't overloading the cat. Once the cat gets cranking well you can open the air up more and still have a clear plume, true?New method:
Verify cat glow and wait a minute or so and turn thermostat to 3 o’clock to snuff out almost all flames. Very small amount of thick gray smoke out of the stack that doesn’t go very far. Smoke lasts 20-30 min as cat ramps up, then clear plume.
Pretty cool, good one.Has anyone else noticed how there’s a Blaze King in almost every house on these Alaska shows? Buying Alaska, Alaska the last frontier, etc. Pretty cool!
No doubt. Output/hr. EPA numbers for the King are approaching his Regency 3100, plus the King has the jumbo box. It probably would handle his place, no problem. The next highest-output BK, the Princess, is a big step below the kind of heat his 3100 can crank out when needed. Based on what he's observed, having run both stoves, I have to believe the numbers are accurate in this case.bholler needs a King!
Did you have an insulated block off plate above your insert? Did you have insulation behind it?
As far as clean burns I saw smoke less often and less buildup from the regency.
I am not sure why you think things aren't right. I had a similarly sized stove with the exact same setup. What makes you think the bk could put out the same BTUs over that much longer with the same amount of wood?
Don't get me wrong I am not frustrated. The stove is heating my house well. And it is more even heat for sure. If I had bought the stove I would probably be disappointed in the lack of magic but it was lent to me for a season so I am out nothing and it just gives me more experience.Yes and yes. It was "professionally" installed by the dealer I bought it from. The next model up stuck out of the firebox a foot...and the bigger one wouldn't fit. I was assured the Regency would do the job. I'm sure you have heard that somewhere before...
But it didn't. Like I say...I feel your frustration. It sucked to have to move the couch right in front of that POS to feel that glow...and to spend all of that effort putting up wood for such poor perfomance. But hey...that secondary tube flame was fun stuff to watch...even if it didn't do anything to produce any heat.....oh...yawn...
I think the way I do because I've ran a lot of stoves. I got rid of an old Buck stove that would eat the same amount of wood the BK does in a day...in less than 2 loads...loads that had to be stuffed in that stove every 3-4 hours. It DID put out more heat than the BK! However...I don't need or want all of the heat in such a short period...know what I'm sayin? I'm sure a glowingd red, out of control firebox will put our more heat time and time again over the BK...if PEAK BTU's is all someone cares about. That isn't the focus here or why anyone buys a BK that i know of.
But hey...whatever, ya know? It is what it is.....like everything else on this rock. All you can do is adjust and go on.
"Troll" implies that I'm trying to get a response from you who have already bought in. No, just trying to get a few newbs to research further before they spend their hard-earned money. Now, I would have hung in there longer than that guy you mentioned that took out the BK, and tried to come up with a solution rather than take the loss...but there have been some others on this thread lately who have bought, then started second-guessing it when they read later about smoke in the house or crumbling cats, issues they should have already known about. I say, do your research first and know what you are getting into, don't just jump on a bandwagon. The entire litany is there in the BK threads of yore
Don't get me wrong I am not frustrated. The stove is heating my house well. And it is more even heat for sure. If I had bought the stove I would probably be disappointed but it was lent to me for a season so I am out nothing and it just gives me more experience.
So, as a sweep, I’m guessing you get pretty good pricing on 8” pipe, bholler? ;-)
I’ll agree, these stoves aren’t magic, they just releasing a fixed load of BTU’s over a fixed time. But I will argue they do a better job of releasing them at the rate YOU desire, at a more constant rate, than any other stove I’ve seen. They can also do it at a lower rate than any other stove on the market, when that is what is desired. That’s the only “magic”.
As to Woody’s pricing and “sheet metal box” comments, like so many other products, I suspect the overall manufacturing cost is just as dependent on R&D and compliance testing, as actual BOM cost. BK’s R&D and compliance testing costs likely run higher than most, due to the thermostat design. I’d also include marketing costs, as well, but I’d bet BK is below other top contenders in spending on advertising and market research.
Yep, the wind is huge if your house leaks some air, like mine. It's a log home; Chinking is pretty good but the corners have some gaps between logs that I'm not done fixing yet. With no insulation, wind pushes though between the logs and wallboard, and sucks heat away. Still need to seal electrical outlets too.we are on top of a ridge in the mountains so we have near constant wind. That is what causes the most problems.
Well, I guess the higher the room temp in relation to the outside, the more heat will be sucked out of the room faster. That could account for some additional wood use..I'm not sure how much.I knocked my wood use by about 1 cord going from the Endeavor to the BK. The Endeavor was a roller coaster, it dumped huge amounts of heat into this place early in the burn then tapered off.
Like you, we had almost no shoulder this year, and I'm a good hundred miles south of webby.if your shoulder season is half your heating season a bk makes perfect sense. But mine isn't even 1/4.
Yeah, it's not like it's gonna be hot enough to burn your lips.I bet that Princess is full of lip marks!![]()
If you're like some of the kool-aide-drinkin' hole-riders here,if something comes along that blows the BK out of the water on performance...I'd entertain owning such an appliance...in the 40 years I've been burning I've never had a stove that performs as well as the BK.
That's right, all stoves involve trade-offs, and that's been my point all along.No...they aren't perfect.....but what is?
Yep, BKVP has mentioned testing with the thermostat as an issue. The Woodstock steel stoves have variable secondary air, and the PE stoves have the EBT but that's different, not controlling the primary air. He's also mentioned the load shifting, but that could happen in any stove. At any rate, I'm not sure I'm buying testing problems as a big expense over the long haul. I haven't been there for the tests, though, so what do I know?BK’s R&D and compliance testing costs likely run higher than most, due to the thermostat design.
Well, you wouldn't have to double the size, but if you did you would burn longer between loads.why would I have to double the size of the bk to heat a house I could heat with the 3100.
If I could find a plate-steel stove that did what I wanted for 2/3 the price, I would go that route instead.And no I am not buying a king.
