Yes it is, provided you don't have flames hitting the face of the cat to raise it over 900 degrees. The only other way it can get that hot is if it is burning something (smoke.)So glowing is not confirmation of a working Cat.
My 30 foot chimney pulled more than 3x the maximum allowable water column for my BK, so while things can vary, I’m betting this is your number 1 issue. Thankfully, I had an identical stove in the same house, burning identical wood on a 15 foot chimney, to help me identify the chimney height as the source of my troubles.
Get a Magnehelic and a key damper on there, already!
I don't think you could get it to glow if it was dead, but I am not sure why the durn things glow in the first place. I understand that the surface is a wash coat of alumina (melting point 5000+, shouldn't be near to glowing at 1500) with palladium (melting point 2800) on it. Maybe the glow of a functioning cat is not incandescence at all, but rather combustion? Or is the glow incandescing palladium?
I don't know much neither but I will tell you something. When I come back from work as an example. I have plenty on chunks in there, black charcoal. I raked them from the sides to the center and as front as I can. Shut down everything and let the air wide open. Went outside and comeback half of an hour later. The probe was at the end of the scale and the cat was not light up.But without a functional catalyst, as the BK thermostatic control drops airflow, the stove cools, and then tries to climb again in temperature when cooler and the stat opens up, it may not get hot enough to re-light off the catalyst
Stove coming out in two days. Had dropped out of this thread as no sense in beating this horse, but a notification email popped in with your post and….. finally, someone who has described exactly what I am experiencing with a BKP.
So before stove comes out in a couple of days, why not ask a fellow Coloradan with a BKP, where is the smoke smell coming from? Do you know? In a closed system, OAK to chimney cap, this should never happen. Having spent a lot of time tracing this smoke emission, to the left fan vent which makes zero sense for a lot of reasons, but that is where it strongly locates to.
Anyway, there are other issues but on this, would be curious to learn your opinion on where this smoke smell emits from in your stove??
And yes, I know BKVP could have helped.. but there are other events that occurred leading up to by the time I got to hearth.com, well, I explained those to him privately.
tx
Got my king this fall, had the same issue. I ended up loosening the door latch 4 turns. About once a week i got 1 turn in till back to where it started. After being shut and burning 3 days it was a lot easier to shut the door.Speaking of door seals I’ve got a new King Ultra and the door seal seems very tight. When the door is about 4 inches from being closed I have to push it with both hands to close it. The seal is very tight on the door hinge side. I assume this will wear in
Thanks Goose it’s tight on hinge side so hated to loosen latch guess I’ll see what happens after a few burnsGot my king this fall, had the same issue. I ended up loosening the door latch 4 turns. About once a week i got 1 turn in till back to where it started. After being shut and burning 3 days it was a lot easier to shut the door.
View attachment 234308 Grandson checking out the new King Ultra capacity
@jetsam I have NO idea how you are getting these burn times. You must have perfect conditions! That’s awesome.
Nope! Start with a hot stove. Pack it full of dry oak including some big splits. Turn the fan off and turn the thermostat way down. Come back tomorrow.
The brochure says 27 hours, and I believe they do their testing with fir.
20+ hour burns are kind of irrelevant to real world stove operation for me, though. I need it to be better than 12 or 14 for work, and I tend to reload at that point no matter how much fuel is left in the firebox.
Some people use them often though. Ashful for example runs one of his Ashfords on a 24 hour cycle almost all season.
Don’t be too jealous the credit card bill just came in the mail scared to open it.I am deeply jealous of your stove.![]()
If I turn the fan off, then the rest of the house gets cold.
To be clear, I’m doing daily 24 hour burns with the fans on, but on a low setting. I’ve also done over 30 hours active cat many, many times, with fans on. I am burning almost 100% oak the last few years, so while I don’t keep a log book of what’s in the stove, I’d be willing to bet it was oak on each 30+ hour occasion.See, there is my issue I think. If I turn the fan off, then the rest of the house gets cold.
Cat observation. If the cat is glowing and the holy plate is not, the cat is working
I liked Ryan’s post, a glowing cat is going to be close to 1000F, a temperature likely sufficient to provide secondary combustion, with or without any catalyst remaining on the combustor.
As to why they glow, that’s basic thermal radiation. All objects above 0K radiate all the time, but the wavelength varies with temperature. This wavelength of radiation is a spectrum with a peak, not a single frequency point, and the location of that peak has nothing to do with material. It is dependent only on temperature (jetsam), and at room temperature this peak is in the infrared, outside of the visible spectrum. When you heat it, the peak of the radiation curve moves into the visible part of the spectrum.
However, since all materials have emissivity that varies with wavelength, and metals have lower absorption (and thus emissivity) in the visible spectrum than ceramic, this peak can be more suppressed in ceramic. In other words, the ceramic cat will glow at the same temperature as a steelcat, with or without its plating, but the intensity of it may be too low to detect in a room with ambient lighting.
Oh, I should add, I’m just an engineer, albeit a very expensively-educated one. “The Oompa Loompa’s of the scientific community,” according to Sheldon Cooper. For a real explanation of this phenomena, we would want to consult a real physicist, but then there’s the problem of getting them to explain it in terms we can all understand...
Oh, I should add, I’m just an engineer, albeit a very expensively-educated one. .... For a real explanation of this phenomena, we would want to consult a real physicist, but then there’s the problem of getting them to explain it in terms we can all understand...
Any time I have ever quoted with my BK’s is with the fans on. I turn them on in October, and generally don’t remember to turn them back off until June.
