The fan kit takes the place of the rear heat shield. It’s either or, the fans don’t have to be running to make it compliant either. You will remove the heat shield and replace it with the fan kit.You read my mind, Poindexter. Was just Googling the convection deck, fan kit and installation instructions. We do have the heat shield on the back- is this a problem with installing the fans? Also, obvs, the stove is installed. The Blaze King installation PDF recommends installing the fan kit before the stove is installed, in case clearance is an issue. Did you have issues replacing your fan kit with the stove in place? Also, is it a package deal, the convection deck and the fan kit? I'm a little fuzzy on that part.
Is the fan kit about the same level of fan noise as a box fan? I do get burned out on the sound of the fan blowing, I even got burned out on the sound of it in the hallway when we were sitting in the living room, but there's no doubt, it does help move around the BTUs. Using the fan to push that heat from around and behind the stove is insane- it's making all the difference in the temperature in the house. The outside temps are dropping and the inside temps are rising. The bedrooms are even warmer.
So, how would you compare the fan noise from the BK convection deck to a standard box fan? Just so I have that in my head, so my expectations are realistic.
I originally demanded the rear shield over the BK convection deck and fan kit because I wanted the stove to be code compliant and safe when used during power outages. We've since had a whole house generator installed. I'd hate to burn propane to run a generator to power a box fan or a convection fan during a power outage- but if we were using the furnace, we'd burn propane to run the furnace fan, in addition to burning propane in the furnace, so OK.
As soon as I get my head wrapped around what this package involves (fan, deck optional or fan and deck together) how to install, and how much I should expect to pay, I'm going to order one.
Any recommendations on suppliers? There are no BK dealers within 100 miles of us, so I suppose I'll be ordering it online anyway.
Thank you for the input, as always!![]()
The one you posted goes to a BK Briarwood I think, not a princess or king.
