Oh ok, I see. You like the long onesYeah, I'm sure a lot of people will skip over it, that's fine and why I don't hesitate to make a detailed post. I've skipped plenty of shorter posts myself that I had no interest in.
Yeah, I'm sure a lot of people will skip over it, that's fine and why I don't hesitate to make a detailed post. I've skipped plenty of shorter posts myself that I had no interest in.![]()
Highbeam, have you tried the "mini-rocket stove" technique I mentioned last week? I'll elaborate below the re-quote:
I light the whole load at once and am not into partially filling the firebox. So I don't have room to be building tee-pees or rocket stoves where fuel should be. Perhaps that dooms me to forever have long, smokey, warm up times in the BK.
I do use red cedar kindling and everything is well under 20%, actually in the mid teens last I checked. If there is anything sub par it would be the old cat that still works great but not as good as new.
I do notice that the plume color switches from white to blue after cat engagement. Then cruises for awhile before going clear, aka "stealth".
It is difficult to overfire the BK stoves as the thermostat limits the temperature. This is wonderful. Can it be overfired? Yes, but hard to do. I believe my steel welded cast-iron clad stove top can operate in the 600s but that would overheat the house.
That is not an overfire. 600 degrees on a steel stove is just gettin started!Hate to disagree, but, it is very easy to over fire my BK. I can run the stove top well above 600 and have the cat thermometer above and beyond the active range.
I do keep a close eye on it when I have the stove above 2 on the dial.
Kick the load off at once on your BLAZE KING. Perfect for me. I am not worried about over firing my stove, I understand that. I don't have to worry about emissions at all (my sauna stove is only 9 feet from top of flue and smokes out my Marxist squatter neighbors), but it is good to know that as a system the BK stoves can operate like that. I'm feeling better for spending more money on a BKYikes, that was long. BG will probably accuse you of writing a "rant"
When is true you can have those dificiencies with short chimney sometimes is hard to predict. Also is hard to predict if the 15' recommended by the manufacturer will perform like it should. Everything depends on many factors but it is a good starting point and go from there.What performance issues will low draft typically cause on a cat stove like a BK? Just the inability to burn as low and possible smoke issues when openi
What performance issues will low draft typically cause on a cat stove like a BK? Just the inability to burn as low and possible smoke issues when opening the door?
I've only got an external chimney that is only 13' from firebox floor to the top, and the Ashford 25 calls for 15' from top of insert, so about 17' from bottom of firebox. Just curious what kind of issues I might expect if running below the minimum.
Your stove won’t overfire unless the door gasket is bad or you leave the bypass open.
The primary issue is a limit on how low you can burn. I see enormous difference between my two stoves, in this regard, having 30' and 15' chimneys on the same model.What performance issues will low draft typically cause on a cat stove like a BK? Just the inability to burn as low and possible smoke issues when opening the door?
HCorrect me here are you saying after you set t-stat to lets say just till the flame goes out you are not required to control the blazing orange cat glow with the t-stat or just walk away and go polish hot rods?
We have to assume that all of our appliances are functional and working as designed. If so, only a bad door gasket or open bypass can cause problems as webby said.
Correct me here are you saying after you set t-statHighbeam ?. You can feel safe walking away from the stove as it ramps up to full boogie!
You set the thermostat for the burn rate you want and go away. The thermostat turns the air up and down to meet that burn rate.
As a new stove owner it's a little confusing and you feel like you need to adjust the dial sometimes, but once you get used to the stove you will probably not touch it other than to reload.
In the winter I usually adjust mine twice a day (a lower setting in the morning, and higher at night).
