You got it! I’ll gladly join the dozen or so others. You are the one and only after nearly 10 years on here.
Yes, where the edge of the door contacts the body of the stove. I have been very gently with it even, and still have lost paint. It sounds like it opens about as much past 90 as yours does.
I am normally gentle with things but old habits die hard and the stove the Chinook replaced opened 180 degrees. When I opened my brand spanking new Chinook for the first re-load, I naturally tried to open it well past 90 degrees. Ouch! It took the paint off a vertical line on the face of the door. Fortunately, I'm more into function over perfect appearance and the Chinook has function in spades. Although it would have more function if it could open closer to 180 degrees because I'm right handed and have fairly broad shoulders. reaching in for a hot re-load puts my left shoulder near the hot door.
I can't think of a good solution other than continuing to be gentle with it. If it's any consolation, I couldn't see the missing paint in your photo even once I knew exactly where to look.
It’ll just put a mark on the stove face. No biggie, it’ll match all the other scuffs after a short time.Yeah, I'm over it...just wondering if it eventually causes paint to chip off or some crap.
Highbeam, I have noticed alot of people mentioning "burning down the coal bed", on their BKS and other stoves. Why is this so nowadays? Is it something to do with the combustors? I've burned wood my whole life and for 14 years in south carolina. I have four stoves I currently feed at my place. Should I try to burn down the coals in the BK, before reloading? I'm putting a princess that I got for free in my shop if I like the ashford.
I burn fir, and lodgepole. But....I decided to get some 24 inch dead standing, clear spruce for my shop, and garage. ( I like our high ravine spruce better than lodgepole, and all the west coast migrants won't touch spruce). Thanks
I think I’ve seen it discussed more with non cats than BK’s. It’s an issue typically when you are pushing a stove too hard. Under normal circumstances it’s not a common problem. Extreme cold, huge house, etc..Highbeam, I have noticed alot of people mentioning "burning down the coal bed", on their BKS and other stoves. Why is this so nowadays? Is it something to do with the combustors? I've burned wood my whole life and for 14 years in south carolina. I have four stoves I currently feed at my place. Should I try to burn down the coals in the BK, before reloading? I'm putting a princess that I got for free in my shop if I like the ashford.
You won't ever have a coal problem unless you get your hands on sone hardwoods. Spruce/fir/pine do not coal very much at all.
Stove size relative to the heated area too. We saw it a lot when temps dropped below 20 with the Castine. Not so much so with the T6 now.I think I’ve seen it discussed more with non cats than BK’s. It’s an issue typically when you are pushing a stove too hard. Under normal circumstances it’s not a common problem. Extreme cold, huge house, etc..
Well, that's not exactly true but I'll excuse you since you don't have Douglas Fir back East.
I very got a confession. I use to curse for not having some good old doug fir when I was burning red oak and hickory in the south. Maybe I was just use to burning wood in my own territory but the season time, and wear and tear on chain drove me nuts. Now I'm home again, I wouldn't trade a load of fir for oak. Even though I know I could dry it much much quicker here.
I had a first today. We installed a Jotul 602 for a lady. She said she’s burned wood before, and knows that trash and the like aren’t good to burn, and cherry. What? She’s always avoided it, she was told that it was bad,” had poison or something in it.” Cherry might just be my favorite to burn. Ive got 37 acres, not a single cherry tree! Mostly just Oak and Hickory..I like burning doug fir too. Normally we burn doug fir and hopefully have a reserve of hardwood. This year the hardwood is locust, cherry and madrona. When it gets really cold out, I like me some locust.
Some people believe the wood of certain fruit trees contain arsenic as the pits do contain arsenic compounds. Apple seeds contain an arsenic compound. If it was a lethal form, I (and my chickens and dogs) would be dead toxic waste. Pressure treated cherry is a definite no burn as it is lethal to cats, people and other living creatures.
That's what I did. Bust out the terracotta that is. It took longer to pull the pieces out of the clean out than it did to break them.I fired up my Princess for the first burn of the season tonight. Currently running on a masonry 6”x6” flue, 20’ tall. 2’ vertical then a 90 into the thimble. Only about 16” of horizontal run, it’s performing awesome! I will most likely bust out the clay tiles to make room for an insulated liner before winter though.
It’s typically not a big deal, sometimes it can be a total pain though.That's what I did. Bust out the terracotta that is. It took longer to pull the pieces out of the clean out than it did to break them.
