rwhite
Just bought and installed duravent dvl double wall. Elbows were around $42, 24" was about $75, and the 6' telescoping was about $100. The manual says the pipe will fit most stoves (which it did on the princess) otherwise you need a starter section. The 3 existing holes on my stove collar didn't line up so I drilled new ones to match the pipe. The manual has all the offset tables and run lengths. If you run a plumb bob and see how far off you are the manual will tell you what length to put in between elbows. To my knowledge you can't run double wall elbows back to back, there has to be a connector piece in between.Thanks! post up a pic. I'd like to see it! I wished we ordered two weeks ago and had it operational for Christmas.
So does anyone run the double wall pipe that BK suggests? I've always run single wall black pipe from stove to thimble.
