Side shields are an option on the parlor and classic models, for corner installs.Thanks for the additional info. and clarification.
Do you have any window frames or electrical boxes that arent leaking cold air? the degree loss per hour you are describing for your insulation envelope is epic.
There's a fixed BTU count in 2.5 cu ft of ash wood. There are only three differences between your old Buck and your new Ashford, in this regard:
1. The Ashford puts a larger percentage of those BTUs into your house, and less up the chimney.
2. The Ashford allows you to but at a very low rate, without gunning up your chimney.
3. The Buck may have been able to extract the BTUs from your load of ash at a slightly higher rate, 4 hours, versus the Ashford's 5 hours.
I'd think the difference in efficiency between the stoves would be enough to make up for the 20% difference in burn times, unless your Buck had a much larger firebox, in which case the difference in burn rate was even greater.
Bottom line, 1800 sq ft should be a slam dunk for any BK 30 stove. Your house may lose heat faster than mine! What's the construction?
Until you can get some of the air leaks sealed, the blower will help replace the warm air being sucked out of the house. The BK guys say you want to match blower speed to the thermostat setting. In our neck of the woods, winters aren't too bad and once you tighten up the envelope, that stove should handle your place no problem. Have you got insulation in the walls? I had the mighty Buck 91 at my MIL's house but it had its hands full with no wall insulation, stove at one end of the house instead of central to the layout and 9.5' ceilings. Heating power only goes so far...
I assume you are talking White Ash, which is the only Ash I've seen here so far. I've only been into species ID for about 5 yrs. though. It's good heating wood, on par with Red Oak and hard (Sugar) Maple. I have a moisture meter but after a while you get a feel for how dry it is by how heavy the splits are. It usually has lower moisture when cut than many other woods, so will be drier sooner than say Red Oak. Still, I like to have Ash split and stacked
So I've read about this issue in a few threads. Did anyone ever find a solution? I purchased this stove used but there is no warping or any sign of over fire. The door passed the bill test. But there is still the "bubbling " on the lower corners of the glass. I actually can't tell if it's bubbled or etched but you certainly can't scrape it off with a razor. No other cleaning method has worked either. It is original glass with blaze king etched in the lower corners.Anyone's glass bubled on the lower sides? I usually use a razor as well to clean off my glass, but it doesn't work as well where it's bumpy. Bought it like that. Didnt notice it till i got home. Any idea what new glass runs?
This link may give some indication as to why:So I've read about this issue in a few threads. Did anyone ever find a solution? I purchased this stove used but there is no warping or any sign of over fire. The door passed the bill test. But there is still the "bubbling " on the lower corners of the glass. I actually can't tell if it's bubbled or etched but you certainly can't scrape it off with a razor. No other cleaning method has worked either. It is original glass with blaze king etched in the lower corners.
Just for clarification: it's not bubbled in the sense of large bubbles, more like it just has a rough texture.
Mine just looks a bit cloudy, kind of like shower glass, in the corners. You can feel the roughness when you scrape it. Certainly I'm not ocd enough to replace it. It may become unnoticeable when burning. I have yet to get the thing hooked up. Need the darn snow off the roof!My glass has some fine, "poc marks" or little etch dots in the area that typically is coated with creosote in a BK. The lower corners. It's not so bad as to be distracting but I notice it when I'm cleaning the glass. Can't even feel them with my fingers or hear them when I slide the blade across.
We've only had low 20s which is rather tropical. But we've gotten our yearly allotment of snow in the past 3 weeks. 2' high and risin.I'm sending some cold your way!
Imagine yourself in a field surrounded by more oak than you can split in a year. Now tell me you're going to use a few of those precious hours away from this pile or oak to go split some pine or fir.The BK owners on hearth dot com, converting easterners to burning softwood one scientist at a time.
Who cares? I haven't seen mass reporting of failing fireboxes.Firebox thickness in the BKs?
Idk but it seems like it goes all the way from the outside to the inside.Who cares? I haven't seen mass reporting of failing fireboxes.
Is this how you treat new members who ask reasonable and legimate questions?It may be irrelevant to you but I care...as I had no idea. I joined this forum to get information to make a informed decision as I have not looked at or touched a wood stove in over 25 years...I didn't know these cat stoves even existed 4 weeks ago.Aside from that these stoves are not cheap and I am not independently wealthy so this is a major decision for me and I would like all of the information I can get prior to making a purchasing decision.Who cares? I haven't seen mass reporting of failing fireboxes.
Ain't gonna happen.![]()
Thank you sir... I find the concept of these cat stoves extremely interesting considering my last stove was a fire breathing dragon of yester year! I am looking forwards to getting one!Ask away Tar, we will respond the best we can.
It will be placed in the center of my home but not in the center of the room as this is not possible. The flue will be run straight up with no twists and turns. A 15 ft chimney height is going to leave a substantial amount of pipe rising upward.How and where the stove is placed is very important. Middle of the house for more even heat distribution. Middle of a room to place the flue so it will mostly be in a protected attic. Draw is very important. It makes for a shorter, more accessible and better looking flue too. The "Little Giant" ladder works well on roofs as it will accommodate the pitch angle of most roofs.
You being a previous wood heater will really appreciate the operation of any of the BK cat stoves. These stoves might be a little more costly than others but are well worth it. The operation of the cat is wonderful as it is a true integral part of the stove's combustion process. Light-off can easily and quickly be attained. Once lit it stays lit. I could go on and on about my Ashford.
A BK 30 series or the Ideal Steel HybridWhat stove are you looking at?
This is the type of info I am looking for!! No trolling here...I am just trying to get my head wrapped around everything to make a informed decision. I am having the chimney installed in 2 weeks and getting closer to pulling the trigger! I am going on vacation next week and I am running over to the BK dealer closest to me and check them out first hand.I apologize that my answer didn't come off as it was intended. I assure you I had no intent of mistreating you.
There has been much discussion and trolling on the subject of BK firebox thickness, with at least a few attempts to imply they're somehow inferior, because many cheaper stoves use thicker steel in their firebox construction. But, the bottom line is that despite a large fraction of the folks on this forum using BKs to heat their home, you will be hard pressed to find cases of firebox failure under normal use in these stoves.
The overwhelming majority (like damn near 100%) of firebox failures reported on this forum are cemented cast stoves, not welded steel boxes.
