My Auber digital should be here soon..
Those are supposed to work well and you can read the digital display from the couch. I frequently ask the wife or kids whether the cat is active yet during warm up!
Inside air or outside air, the combustion air will get it's heat from one source-the burning wood. With the OAK the thermostat might open slightly more to compensate but using room air means the house will be cooled by air leaking in from the outside via cracks. Rooms further away from the stove might not heat as well due to outside air infiltration. If you tighten up the house and prevent all leakage, the fire will become unstable and a window will have to be cracked to provide the required combustion air. Some people like the air change not using an OAK provides. I didn't care for the draft from my leaky front door so the OAK, for me, is an improvement. An added bonus is when my wife turns on the kitchen exhaust it does not pull smoke out of the stove. I did have a stove that did not have outside air as an option. That was a constant problem as opening the front door in winter sucks.
Burning Doug fir and larch in my princess ,3 months burning 24-7 I took out a coffee can of ash.[emoji41]How often do folks dump ash? I'm a month into using the BK and I may have 1.5". Burning d-fir and lodgepole. It's been in the single digits so I'm only getting 12-14 hours on lodgepole. But I'm keeping the house at 78 too. Never been happier or more impressed with a stove.
I been hitting the lodgepole pretty hard lately. Figured I'd dump it today and clean the chimney. Got about 2 large coffee cans worth. That's been about 1.5 months worth.Burning Doug fir and larch in my princess ,3 months burning 24-7 I took out a coffee can of ash.[emoji41]
Sent from my XT1585 using Tapatalk
Heh. There's a older king up for sale locally and I'm curious if anyone knows much about them and can help me suss out what exactly it is.
Here's the info the poster lists.
Model KEJ1001 Serial # WH 4100881
Curious if they actually mean 1101? Is there a 1001 that's older and noncat? I couldn't find much info on google. Also hard to tell in the pic but it looks like a cat thermo? No?
Here's the only pic they put up. I don't know how to rotate it. Sorry.
It's described as like new condition. A possibility for the shop maybe? It's cheap cheap cheap.
Perhaps you stretched the gasket a little when you installed it?Replaced the gasket on the princess insert.. OEM 7/8", no issues and I think I did a decent job. Dollar bill test results surprising though, not very tight on the latch side. Below pic shows not much of an indentation on latch side. Should I try adjusting the latch? I thought maybe would need to loosen the latch but not tighten? Closing the handle is tougher now than my old gasket so not sure what to make of this..
I'd just tighten the latch a turn and be done with it.Possible I suppose, I wasn't really paying attention to not stretching it.. that would suck because I really don't want to have to do it again..
Do you know if yours is new enough to have a nut on the inside and outside? The older ones had a nut on the inside that was welded on, these are likely to just break off. If yours is welded on I'd recommend heating it up with a map gas torch while working it.I'll give it a shot when she cools down.. any tips? I read a post or two about the latch breaking
And or, get an upgraded latch and handle and just plan on changing them both.
Most likely. Soak it with PB blaster for a while. Then heat it up and I'll bet you'll be fine. Might be overkill, but that thing will snap in an instant! Better safe than sorry.I've got a PI1010 which is according to BKVP the release prior to the popular 1010a so I might be in the camp that has the welded nut
