How far up the stove pipe is a good spot to get a accurate reading for temps? I have double wall. Obviously the closer to the stove the hotter the reading. Im using my ir gun on the black pipe, the cat is nicely being feed its food for the day.
Do you guys think the reading are to high especially when i get closer tp the bypass? Especially if you take those reading and times them by 2.
Niko, you have some confusion going on. You can NOT get any idea of flue temperatures by reading the outside of double wall pipe. That only works for single wall pipe and then you double the surface temperature to get internal flue temperatures. To read your flue temps you must acquire a probe flue temperature meter from a company like condar, not too expensive and the only way to know your flue temperatures.
On low cruise burns my internal flue temperatures as measured with a probe meter are 400 or higher on purpose, they could go lower without stalling the cat but then my chimney turns into spooge city. The stat closes during the startup one hour long high burn with peak flue temperatures as high as 900. So 400 to 900. If you had a single wall pipe, the surface temps would be 200 to 450, pretty much the normal range of any good flue temperature meter.
With the probe meter that you need, the manufacturer specifies the distance above the stove. As I recall it is 18" but the directions will say.
Thanks man. Gonna order one thanks.
I think this method is just fine for people ideal chimney set ups. With a minimal flue, the cat can stall and it can also overwhelm the cat and puff smoke into the room. Kinda like the old VC's would do.a few pages back there was a discussion about weather to turn the thermostat down to the desired setting all at once or in small increments. I close my thermostat from 100% open to my desired setting about 50% all in one move. What is the difference between the two methods? Is there some benefit to one way of adjustment over the other?
Right. If I'm trying to get a quick light-off from stove/flue temps that are not as high, for as long as I usually aim for, I'll close the bypass and keep some flame going in the box for a while. This will keep heat going to the cat, albeit less smoke, but the cat will glow. Then I cut the air down to cruise setting in a couple of steps.me, personally, sometime see a difference.
EXAMPLE: Let's say that is at 600 stove top thru those 20 minutes burn.and i dial it down to like at 1.5, I notice sometimes that minutes later start dropping to around 575 or so and the cat is not lighting off bright.. if i do it in a few steps but the time i set it in low ( 1.5 ), temp keeps rising and it can touch the 700 for a while and cat light off good keeping the temp up there for awhile.
I think that you are giving more time to the gassing from the wood without choke it to soon
Most likely. Soak it with PB blaster for a while. Then heat it up and I'll bet you'll be fine. Might be overkill, but that thing will snap in an instant! Better safe than sorry.
Shouldn't be an issue. If yours is the old style with the all round catch then it will wear the door latch a little faster.PB blaster did the trick, didn't take much at all to turn the nut and nothing broke, whew. I really got this latch tight now, dollar bill test passes flawlessly now. Any issues with too tight a latch? I'm guessing I might be really crunching some of my gasket now, but as long as it's not hurting anything...
Yes. You will be best off getting the upgrade kit.Cool, replacement parts are available right? Doubt I'll need but good to know
I listened to the BK Wisemen here and turn down in increments from wide open to 3 o'clock and on avg settle some where in the 2 o'clock to 2:30 range.The wife enjoys a warm house...lol
Yeah, I heard the company is on the verge of bankruptcy....the mods need to try to save them, if it isn't already too late!I dont appreciate the Blaze King name being tarnished....the browsing person sees negative and the damage is done...Moderators you need to make new rules!
If you can afford all that, you can afford to give my sis a good deal!Then is time to buy not just one more. 2 or 3 of them and a dozen of cat to be cover for the rest of my life.lol
