Ashful
Do you want each of us to reply with a "no, not me?"Hello, anybody ??
Knock,Knock, Knock,.....Is this thing on ??
Go outside and look up...if you see smoke (not steam) after 10-20 minutes of reloading, it may be time to clean or inspect the combustor.
Well, I can't believe nobody has done this..
I can. Why on earth would I want to convert to an electronic cat probe meter when the existing one works so well? Is this just a solution looking for a problem?
The digital meter tells you what's happening "right now" with the cat..
Not what was happening several minutes ago..
Think, wife loading the stove, here !!
Looking for some advice. Last year my stove seemed to perform better. It's a ashford 30.1 new last year. Last year I could load the stove with less than perfect wood (10 month css cherry ash and soft maple), burn on high for 30 minutes and turn it all the way down. I would easily get 24 to 30 hour burns with great output without stalling the cat. Keeping the stove room about 78-80 degrees. This year my wood is css 22 months and if I try to run the stove the same way the cat will stall in about 8 hours?
So here is why I don't consider that important for operation. Following the directions and engaging the cat when the cat meter (even delayed) says "active" is conservative and means that the cat really really is ready. That's a good thing. Wife can load as soon as the meter says active just like the owner's manual dictates. Some cat manufacturers even suggest that you should maintain active temperatures for 20-30 minutes before engaging the cat.
I suspect that you like gadgets and that's okay.
Thank you. When I go to look for the smoke is that while burning on high after the reload? If I do need to clean it what's the best way to clean it?Catalytic combustors are not 100% for their entire lifespan. Their performance ha so much to do with amount of fuel burned, burn rates, fuel etc. Go outside and look up...if you see smoke (not steam) after 10-20 minutes of reloading, it may be time to clean or inspect the combustor. Your maintenance is excellent, but shorter burn times are not usually associated with combustor activity, rather air leaks, significant stack effect due to extreme cold weather and other variables (specific gravity of the fuel, MC).
Thanks.Cat info and how to clean it. It worked for me and is safe for the cat.
(broken link removed to https://www.condar.com/combustorcleaningmanual.pdf)
Welp, my stove has a convection deck, so the meter is not real easy to see, I gotta get out my lighter or turn on a bunch-a-lights to see it...
And no, I'm not a gadget nut either, lol...
Many years ago I bought a log splitter..
I know, I know, the wedge and sledge from my teenage years worked just fine..
But, the splitter just seemed to work better for me !!
I have no idea what stove you are using (maybe update your signature so that we can tell) but the BK cat meters are right on top and easily viewable from the front when you are close enough to engage the cat. Yes, you might not know from your couch if the bypass is ready to flip. Maybe that's the only good reason for the digital meter, so you can tell from your couch if the cat is ready to engage?
I like gadgets too. I replaced my original cat meter with a numbered one for the sake of knowing actual temperatures.
Oh, I do use thermocouples and digital display for my meat thermometers in the BBQ. Don't want to open the door until it's ready!
Hardly!A little off subject but I did not know these things existed:
http://cubicminiwoodstoves.com/pages/videos
Burns wood shims, if cut in half. BK look out competition has arrived!
My wood is around 10-15% moisture content and yes I ran it on high about 25-30 mins I noticed it went to 276 then back to 400 and its dropping slowly again so I'm guessing all is well house is nice at 74 love this stoveBKVP says keep the cat active and check your flue in 30 days. The top of the flue might not get hot enough to keep the creosote at bay. Each install is different but I run mine at those low temps too. Fully char each load (~20 minutes) and turn the thermostat down in a few small steps. Charred dried wood (red hot wood has a real low moisture content) is very important.
