Ashful
Thats some seriously random chit right there! Even more amazing is that I read it all.
How old was your cat?
He'll be back in three minutes.
Wife is dressed fetchingly, have to go now.
So we've been getting around 11-13 good hours on fir before I reload, usually with plenty of coals. Tonight I tried out first batch of madrone. Goodness.
I don't know what the burn time will be but on low with for we were running the house around 68-72ish. Right now it's 79. This stuff definitely burns hotter. I'm assuming it's the wood. Weather has been approx the same for the last week or so temp wise. Might save this for the really cold days!
Definitely save the hardwood for cold days. We have a stash of madrona, cherry and locust for the very cold days. I love burning that stuff. It puts out a lot more heat and the fires last longer too, especially locust which burns with a ghostly purple/blue flame. It's like burning coal.So we've been getting around 11-13 good hours on fir before I reload, usually with plenty of coals. Tonight I tried out first batch of madrone. Goodness.
So I am back in the saddle from #1137 above.
With the telescope lifted my pipe looked freaking great. I left work early enough today to catch sunlight at the top of the stack from below and looked around real good with my tacticool 600 lumen light.
I stuck a 500W halogen light in the cold empty firebox and confirmed the bypass gasket makes a light tight seal with the bypass door on all four sides.
The back side of the cat had a narrow band of fly ash along the bottom edge, but I couldn't see most of the back of the cat because of that huge piece of steel welded to the roof of the firebox hanging down into the cat exhaust. I bet I recover a bunch of heat from that structure.
I lifted the cat shield off the front for the first time ever, my BK dealer put it in place as part of the stove install in May 2014. A BUNCH of fly ash on the front face of the cat.
I put the lamp shade tool on the vacuum cleaner, did the back side first and then the face. I was real gentle to not screw up the cat, but a hemispherical chunk, about the same diameter as a penny fell out of the front face anyway. Then I shined my light into the face of the cat, couldn't see jack doodle for light coming through the cat body and got my dealer on the phone.
The guys at the shop weren't overwhelmed with the green on the back, though they noticed it. Once they pointed it out I could see significant cracking in my cat foils. They said if it was ceramic it would be "burnt out" but they don't have a lot of experience with steel cats coming back in.
I had a private moment with one of the senior employees and asked him straight up if he was giving me a new cat because I spend a lot of money there, or was this a legit in warranty cat exchange. I pointed out that my wife was going to ask what I need to differently in the future.... He was all about legit cat exchange.
So I came home with a new cat and a new gasket. Holy press fit Batman!! I was worried the stove was going to start scooting across the hearth, but it didn't. If you get to do one of these the key seems to be once you have it oozing into the dome keep on pushing, because when you stop you have to start all over applying enough force gently to get it oozing again. Much easier to keep it oozing into place than to get it started oozing.
Shine that bright light through the cat to verify that all cells are clear. A healthy blow from your lungs can actually help but a shop vac across the face, use the lampshade brush head, can clear them out too. Just be sure to verify that there isn't a pile of junk in the cat chamber to be sucked through the cat.
At current temps we may not burn any hardwood this year.
Ignore the color and don't worry about lead or copper. You had cat cloggage, pretty common on the other brand and especially so with the smaller cells of the steel cats. I bet it has to do with your full throttle operating style as the WS guys have found that turbulent fireboxes stir more ash which flies up into the cat easier. I can't believe that a chunk of steel cat actually fell off.
To prevent cloggage with your apparently clog prone burning style, you should be cleaning that cat frequently. Lamp shade vac at least. I bet that cat would have worked fine if somebody could have unclogged it but with the cracks and spalling, a new one is the best bet.
Now my question is I wonder if this has affected my cat life?
My SC 30.1 manual calls for 15'. I have 12.5'. Its been really warm out since switching from the SC20.1 so I have not had a chance to see how it will be during cooler weather. At these tempertures I get a bit of smoke rolling out the door which reloading and have to open the door slowly. I have one set of braces....I will likely add 2-4ft of height soon. Just have to make sure the supports I have will work.Quick question for everyone running the 30.1 firebox, what seems to be "enough" chimney height? About to finish install on my Sirocco 30, manual says 12' minimum, I keep seeing on here they now recommend more than that. I have everything in place just need to set stove and hook up chimney. Have 8' above ceiling box and apps 5.5' stove pipe below, all double wall, straight up no bends. Is this enough or should I put another couple feet on right away before I fire things up? Don't want to go any more than another 2' unless absolutely needed don't want t have 2 ugly roof supports one is bad enough...
Well I learned today that the Princess I have been running since the end of October has never had the bypass closed. Let me explain a little, this morning when I closed the bp door (it always stops at the 4 O'clock position) well today it went clear down to the like 5:30 position it moved easily another 3 inches lower.
I had to leave so while on the road I called the stove shop in Bangor after a little phone tag I got a fella on the phone. He told me that yea that lever I supposed to go all the way to the 5:30 position. Mine has always stopped at the 4 position when it moved the additional distance there was a lot of squeaking .
So is it possible... , that my bypass door has never really been closed ? at the least closed tightly? The book says make sure you hear /feel an audible click / clunk to let you know the door is closed.
I think the book should have said " The lever that operates the bypass door may stop at a position that may indeed not be fully closed. Be sure to apply some firm pressure to this handle to be sure it has moved as far as it can,.. approximately the 5:30 position. Failure to do this will not only affect the length of burn times but will create possible temperature's so high they may damage your Catalyst.
Further more you may increase flue temperatures to such a point that this may be dangerous if the stove is left unattended. ~~Just a thought,~~ Kinda glad it did not burn my house down,.. that would have sucked a bit ! My chimney is always in great shape and clean and I watch the stove closely so I doubt this would have ever happened to me but someone new to wood heat altogether this story may not have had such a happy ending.
Maybe we should lobby for a "swoosh" label or would some numbers be better? Hmm, "o'clock " references seem to work fine.Mine went to 5:30. Though I guess we are talking about three different stoves.
Which side of the family??? The "o'clocks" side of the family or the in laws....the "swooshers"?I love this family!
All of them!Which side of the family??? The "o'clocks" side of the family or the in laws....the "swooshers"?
I will agree that these stoves are too boring to run. So much so that I've flat-out forgotten that I hadn't loaded one, on two separate occasions. That never happened with the Jotuls, since I was always watching them.Ten years here and I have never seen anything like this numbers vs. swoosh thing. If the stove is that boring then you really need to get a non-cat to keep you busy.![]()
