Maybe we should lobby for a "swoosh" label or would some numbers be better? Hmm, "o'clock " references seem to work fine.
I was waiting for you to say that.... good job.
Quick question for everyone running the 30.1 firebox, what seems to be "enough" chimney height? About to finish install on my Sirocco 30, manual says 12' minimum, I keep seeing on here they now recommend more than that. I have everything in place just need to set stove and hook up chimney. Have 8' above ceiling box and apps 5.5' stove pipe below, all double wall, straight up no bends. Is this enough or should I put another couple feet on right away before I fire things up? Don't want to go any more than another 2' unless absolutely needed don't want t have 2 ugly roof supports one is bad enough...
Buy a taller house. [emoji14]I'm not going to 15' due to the need for those ugly and potential leak causing roof braces. I hate roof penetrations!
Mmmmm it's mild and snowing here.
So I loaded up last night @ 20:00. Let it rage for a while, shut it down, 1.5 with fans full tilt. Went 18hrs?
So the school of thought is, the higher we run it, the more heat escapes up the chimney? Anyone concur?
Ten years here and I have never seen anything like this numbers vs. swoosh thing. If the stove is that boring then you really need to get a non-cat to keep you busy.
Heat Rises. I would install it downstairs.how many of you guys are using you princess insert in a split level home. I currently have a 1980's fisher stove and I am getting tired of filling up my stove every 4-5 hours and kinda wanna be able to enjoy those long burn times as you guys. so my main question would it be better to install in the upstairs or would the bottom level be good enough to keep the whole house warm. my fisher is in the downstairs and it does a good job keeping the upstairs a nice 70f. thanks for any hellp
Flue temp and flow rate go up so yes, more heat up the chimney at higher burn rates.
So I took the side off the thermostat side of my princess insert tonight to lube her up. I unscrewed the thermostat and applied nickel anti-seize to all the surfaces that "rub". Then I undid the spring on the shaft and don't know if I put it back together correctly. I turned it all the way down and tightened the spring holder in place and reinstalled. When I reinstalled it the flapper does not close. Is that because the stove is not hot? Just wondering if I didn't put it back together correctly?
You are correct. It's pretty tricky and everything should have been marked to ensure it goes back just like it was calibrated at the factory.Uh oh. The insert uses a different thermostat control mechanism since the controls are up front but on the freestanders that little spring retainer set screw collar is very important. That retainer is what hits the max and min stops for the actual flapper. If that thing isn't put to the right place as determined by BK then the reference used for installing the knob is now wrong. You need to call BK now to find out how to clock that set screw collar retainer deal right near the thermostat. When I lubed up that spring I looked at that thing and said, "Highbeam, don't F-with that set screw".
Well you guys convinced me! >snip<
Thanks to all of you for your information about this stove and thanks to BK for a great product. I'm looking forward to many years of a nice toasty home.
I'm pretty sure they do have some instructions. It says not to mess with it!Well, I got it back together after stripping the set screw. I happened to have another one in the stash. I don't think it is right so I will have to call BK but it would be nice if there were some instructions for this. The flapper now goes closed at 1/2 open. I obviously don't understand the spring mechanism. But I am sure I will figure it out but will call to make sure.
