Thanks for the info Ninja Tech. Interesting.
I get a v shaped burn with cord wood and have noticed if I get the stove packed tight there is usually a half a piece against each outer wall buried in the ashes.
Did a little experiment over the weekend, I was at menards and they have those 'eco' brand compressed bricks. Grabbed a bunch of those just to play around with, wanted to go for the long burn. Cleaned out a bunch of ash, raked all coals to the front and loaded up about 4 1/2 packages nice and tight. I was able to get three layers of them in there with enough room left for the bricks to expand. It was just under 100lbs worth. This was friday night around 7pm. Threw a smaller split right on the coals in front to help get the front of the bricks going. The goal was to have the pile to burn from the front to the back nice and slow. Cat started around 1,200F when first getting going, then settled down in to the 800-1000f range for a solid 30 hours then started to drop towards 500 and figured it was time to reload. When I opened it up i noticed the entire bottom layer of bricks had not even burned yet! The ash from the top two layers appeared to be blocking the air to the bottom layer. I stired things up to knock all the ash off and get some air to the bottom layer and they took right off. Cat back up to the 800-1000f range and just kept on going till 8pm last night when the rest of the bricks were ash. Temps outside were 19-32 the entire time, stove room never went under 73. So I ended up with a 49 hour burn on a single load of fuel, with only one maintenance 'stir'. Those things just go, and go and go. That defiantly won't become my normal running procedure, I have a few packages left and when those are gone I'll switch back to regular wood, but it was a fun little experiment.
How much did it set you back for enough logs to stuff your stove? Also, which size box do you have?
What size is your stove?I used about 4 1/2 packages of blocks (20lbs/package), i think they were 3.29 each. So around 15 bucks to fully fill it for two days. Those blocks do seem quite a bit more expensive than cord wood around here, i got 10 packs of them more just to play around with and 'try out' compared to how regular cord wood burns. I do have to say, I really do like them and would burn them full time if they were not so expensive. They really are convenient and do really burn well. I have heard our rural king out here has 40lb packages of compressed wood blocks for 4.99. I may try to make it out and try those too. The cost per pound on those is getting low enough I may consider using this more if they do actually burn as well as the 'eco' brand ones.
Should hit single digits tonight, bring it weather! I'm ready!
It would be cool if the shaft (that connects the knob to the thermostat) had a flat place on it. (this is fairly common in electronic equipment). That way there would be no confusion about where the knob should be positioned, and although it could still fall off, at least it could not slip and get into the wrong position. If BKVP is listening ...Sounds like you just didn't tighten it enough. Back the set screw off until the knob will slide back on. Repeat directions Shane posted and re tighten set screw.
Rusty...it was implemented 30 days ago...just working through stock...clever minds think alike!!It would be cool if the shaft (that connects the knob to the thermostat) had a flat place on it. (this is fairly common in electronic equipment). That way there would be no confusion about where the knob should be positioned, and although it could still fall off, at least it could not slip and get into the wrong position. If BKVP is listening ...
Would you say that they burn cleaner than cordwood? Our clean air agencies claim far lower emissions from manufactured firewood and while I would not want to use them all the time I could see using them when pollution levels are high, when I want to burn without smoke, or when I want an especially long burn time for some reason.
Did the bricks blacken your glass more or less than cordwood?
Did the chimney smoke more or less than cordwood?
Some Menards(Not any near us...), still have the grenheat 38pound compressed log packs at $2.50 on clearance. I use these and they work great! Have not tried a whole stove full. Maybe once its -20f outside. lol
30hrs is impressive never mind 49.
Hard to believe there was any useful heat for the entire time.
okay,
so i fixed my knob on my BK last week. it was working up until the knob fell off. so I dont know what i did wrong. Please help
Mine came loose again, I figured I just didn't tighten it enough. The alan key used to tighten it is so small I was worried about breaking it if I tried to tighten it too much. I just re set it and tightened it as much as I could.
Glad to hear you're changing how the thermostat knob fits. Any way for us to replace what we have for the new kind?
Was there a post on how to "reset" the tstat in case it may have moved?Throw some JB Weld on there once you get it set correctly, won't have to worry about it moving again.
