Like when I mentioned issues being discussed on Hearth.com with certain stoves to the Lopi factory Rep. He literally laughed in my face! He brushed this site off as a bunch of people that just wanted to complain.Amen. And you know what else, he's SMART. It's amazing how many companies (most) in this modern internet age, where people discuss most every product in detail on forums like these, completely ignore what's going on in those forums (or at least don't acknowledge it). That's just dumb.
That attitude lost them my purchase. Look at how Blaze King, by contrast, is selling stoves as fast as they can roll them off the line.
I lost power for a week and didn't have a generator at the time. It did a pretty good job heating the house, the family room was in the low 70's, upstairs bedrooms were cooler around 60-62 with overnight temps in the 20's. I ended up sleeping in the family room that week since I have sleep apnea and couldn't run my machine, I slept in the recliner.Can anyone elaborate on the Blazeking Princess's Insert's ability to heat without a working fan during a power outage? I have a backup generator, but still curious to know what percentage of its ability to heat will be compromised during an outage. thx
Depends on how I load it. If I stuff it I can get 8 to 10 hours but it goes all the way to coals and the house is cold. The cat stays in the active zone throughout until it doesn't. If that makes sense. I am more concerned about the heavy smoke making it out of the pipe. That seems to me that something is not working right.
Okay, I have a problem. I am on my 3rd season with my princess insert. I just don't feel like it has been working correctly since I got it. Maybe I am wrong or my expectations are off. My wife thinks I don't know how to work it. Here's what I do.
Load it up and light it.
Everything is open.
Let it go until it is in the cat zone.
Close it down and turn the air down to half 4 out of 8 dots
Temp climbs and then I drop the air down to 2 out of 8 dots.
Smoke comes out of the chimney at all stages
Wife is upset that there are not flames. I explained that there will not be flames.
Anyway I don't think I am getting the burn times should and there definitely should not be the smoke as heavy as it is out the chimney.
Wood is pine and hardwood mix and is seasoned.
I'm confused.
Thanks for the reminder ninja. I do have a moisture meter and just checked to find 12% moisture on wood I just bought as seasoned. I bet that is too much and always forget to check. I wish I had time to season and find my own wood but it is a little difficult here. I guess that is it and admire your tenacity to check both wet and dry. What a great idea![]()
All the wood is split already. I tested the outside and the inside. 10-12% on each side multiple pieces.
Well it does not sound like your cat is working. Can you see it glow when in cruise or whenever?Yes to both.
It only glows sometimes. Is it supposed to glow all the time? If so it surely does not.Well it does not sound like your cat is working. Can you see it glow when in cruise or whenever?
Also, the thermostat does not move smoothly at all. I watched some do the blaze king you tube videos and it looks like the thermostats move very effortlessly. That is not the case with my princess. Any ideas on that one???
I also will split the split and check the moisture again.
Well it's time to forget all this 'Shoulder season' nonsense!
Currently -20C up high. Around -17C at home. We will see if the BK Hype is really 'All That' or if the forced air poluted my living space last night.
Thanks highbeam! That's what I thought and judge the cat being active by the condar cat temp gauge I put in. Am still wondering about the thermo air flow knob though....The cat is not supposed to glow all time. No glow, partial glow, full glow, all okay from an active cat. What you do know is that if it glows the cat is active.
What the neck is a C? Is that like Kelvin?
Mm well. It was 20.5C in the house when I arrived home. Not bad for 2200sft with the stove in the basement. Stove still active and warm, No forced air activation either.
I loaded her back up and it's now firing on all cylinders. Left her on 2.5. We will see if she catches back up.
'C' means Cold
All I know is 0°C is 32°F oh and boiling point. It's 72 in my house, way warmer than 20.
