So no one can find it?just posted a new thread on the ongoing ashford smoke smell issue
should I burn a hot fire with bypass open and use the thermostat to keep chimney temp down it just seems like when I close bypass flames slow and I don't think it will remove the creosote.
This isn't an answer to your question, but if you're burning on high for a short period with each load and still seeing build-up, your wood might be higher MC% than prescribed.
Can't argue, as I'm not burning my Ashfords, yet. But the BK manual implies that it will stay relatively clean, if you burn on high 20 - 30 minutes after warming and engaging the cat, at least once per day.No, it is normal to get heavy accumulations of tar and glossy creo in the firebox with even dry wood when you burn these stoves on low. The BKs are meant to be smoldered.
Come again?Ummm ... Yeah. Just don't get out the Brillo pad and the comet cleanser and scrub it if it doesn't come clean from those short burns.....heheh ...![]()
Come again?
Translated : You're gonna get creo buildup in the firebox whether you burn small hot fires or not...![]()
Been burning two cat stoves 24/7 for the last four winters, so yes... But the amount of buildup with dry wood is not what I would consider extreme, or worth any bother. The OP implies otherwise, and I saw extreme buildup only in my first year or two, when my wood was higher MC%.Translated : You're gonna get creo buildup in the firebox whether you burn small hot fires or not...![]()
Question: Can you turn the thermostat low enough to crash the cat on a BK, as a general rule, or is the thermostat set up so as to prevent a cat crash, keeping an minimum amount of air going into the box?
OK. I wondered if draft or wood would affect it but figured the stove would be cooler and the thermostat would compensate, but it sounds like I could slam the primary air all the way shut if I turned it way down, and then the air feed holes would take over as long as there was decent draft and the wood was dry enough to keep burning.The stoves are designed under proper operating parameters to have a minimum amount of air flow into the firebox to sustain an active cat. Short stacks, poor draft, little stack effect, moist wood can all influence this of course. We do have holes that permit for the miniumum air flow
Interesting. I wonder how that would affect various stove models. I guess it depends on the stove design, and how low they can run it during the test. With a hyperactive brand new cat, they can probably run really low so in real life that's not going to be an accurate predictor of how low the stove can cleanly run.Incidentally, the new NSPS regulations requires that no stove can operate at a burn rate lower than at which it was certified.
