BKVP
The problem is that there no longer a "setting" to find. I always always set the stat dial to a specific setting indicated on the sticker for repeatable dependable results. Sure, a guy could make new marks but that would be a hack compared to the numbered label. At least keep the gold normal range. The way these stoves burn is set it and forget it, this is great but you need settings.
Somebody ought to go to the house of the bk guy(or gal) that came up with this idea and replace his oven temperature control with an unlabeled scale like that. See how they like cooking bread, cookies, or turkeys. It's the same thing.
You know you're invited over anytime you like. You see my oven is the same as your oven with regard to settings. So when you walk in the door at my house you can use my oven because it's just like yours.
But...on the other hand you would have to get use to my King and how it performs when you point the white line at 2 o'clock, 3 o'clock, 4 o'clock or even full blast at 6 o'clock.
Did you get the package?
![[Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK)#2 [Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK)#2](https://www.hearth.com/talk/data/attachments/157/157147-fdac17595fd1131fbf740b46cd296048.jpg?hash=gdQ0ribopI)
but we run the fan on low most of the time here and it just becomes a little white noise after a while. Meaning we don't even notice it's running until we turn it up or off. We've never needed to run it wide open but it can get pretty loud to my ears but also move a lot of heat on anything above low.
