Find something like a leather glove (welding type) and press against the door frame, as low as you can on the metal frame. If the flame goes away the door has a slight leak that may be adjusted by either tension, or fluffing up the door gasket. If it does not go away, you may have a very slight leak in the door glass gasket.First,I apologize of the orientation of the photo. I suck with personal computers, even though I'm an engineer. It looks as if my door is leaking? There is a strong flame coming in from the lower right corner.
I hadn't burned for several weeks and we have a cold snap right now. In preparation for the coming storm, I cleaned my chimney and stove and checked the door via the dollar bill test. It was a little loose, so I tightened it. Did I screw something up? I'm worried about my cat now.
This is a new stove that I have been burning since October.
Either way, this is an extremely small leak and your cat will be fine. Just don't get burned trying this...so be careful.
Chris
Ashford 30 burners: what is your cut length, and are you loading N/S or E/W. Manual recommends 16", and E/W, but I can't figure why.
Going out to cut a few more cords, today!
I do 16"-18" pieces loaded N/S. I can't tell any difference in how it burns, it's just easier to load.Ashford 30 burners: what is your cut length, and are you loading N/S or E/W. Manual recommends 16", and E/W, but I can't figure why.
Me too! I love square fireboxes. The Cape Cod was so frustrating because it was E/W only. Unless you cut your wood 11" long..Ridiculous? How so? Many stoves, even big ones are designed to burn E/W. This includes the Lopi Liberty, Jotul Oslo, Hearthstone Manchester, Woodstock Progress Hybrid, and others. I've found that I can extend the burn time with hardwood in an E/W config. N/S gives me a hotter, but often quicker burning fire. I like having the option to load the fire either way.
One has what they have. Wood burning is not absolute. There are lots of variables. Wood orientation in a non-smoldering firebox is part of burn rate control. Point being is that both ways have advantages and using them is part of the art and fun of wood burning.
You will need to remove the clay liners to make room for an insulated SS liner. 7" does not leave enough room to install a liner with insulation."Hey dudes...rolling through Merill, WI today found a Princess Ultra burn model (1 season) at a showwroom for $1462.50. If interested let me know.
Chris"
Thanks BKVP. I have been looking for a good deal on a princess and you provided! So now I have a question about the flu, I know it's in, well, not the best shape. But if I install a liner would it overcome the cracks? No visible light and not much smoke in house, most of which I blame on the Ashley. It is good and straight 7" square clay tile wrapped in cement blocks. The thimble is 6'3" to bottom from floor and does not a clean-out have. The chimney is 20' from 4" below the thimble( reach in and clean depth ) to the top of which only the last 2.5'-3' is exposed to air. Is the attic considered to be inside? It is about 7'-8' and easily accessible so could be wrapped with insulation if needed. I guess the first question should have been will a 6" liner tube fit in 7" square tile and does it/will it fit insulation also if needed. Is insulation needed? I think the last question is what to do about no clean-out and how the bend would work behind the thimble? I am excited to try this princess next year cause I spent two years trying to talk dad into one but he was a tightwad that bought a undersized Ashley P.o.C. 3 years ago and I have been fighting it ever since. Also will be glad to be able to burn pine and hickory instead of watching them rot or burn in big bon fires! I am kinda like Ashful and have to start cutting a whole lot shorter then I am used to!! Next year I will be able to join in this fine argument on loading styles, nah I will just do what ever I feel works the best for me or is the most convenient. Now how do I insert smiley oh that works.
Thanks guys and I hope I did not confuse anyone.
Because the current clay flue liner is cracked, therefore it needs insulated.Webby,
Why not try an uninsulated liner, before spending the effort/expense of tearing out that clay tile liner?
By code, if the clay liner is cracked or otherwise breached, it is no longer serviceable. To bring it up to code the SS liner must be insulated.Interesting. So, you can have a clay liner in a masonry chase, but not a steel liner inside the same chase, even if held mechanically by a clay tile liner?
