HOT reloads are the way to go.
I'm a bit afraid to take it out at this point, without a replacement on hand. I'm afraid handling it will do more harm than good. As long as it lights off and the gasket is good, it's staying in there.
Hopefully it's a non-issue for me. I didn't plan on being in here this far thru the winter. The weather the last couple of months has made it really hard to sell a house.
Even before I had the oak installed smoke coming out the door on any type of reload wasn't a problem. Sounds like you have low-D
Lol, low "D".Even before I had the oak installed smoke coming out the door on any type of reload wasn't a problem. Sounds like you have low-D
My former zero clearance wood stove was like that, I had to reload on coals or else. Not fun. One of the reasons shes gon.Could be, but many of us have draft low enough that opening a loading door with a firebox half full of burning wood will result in smoke spillage.
I have a good chimney system that meets the recommended specs. More draft from a taller chimney might be better. Colder outside temps might be better. Nobody likes spilling smoke into the house.
Lol, low "D".
TBH I just run the stove.
Welcome to the 30s my friend...sucks trying to run a stove like this, huh? 30s is about average for us where I'm at in MD in the winter. Wish I was in your neck of the woods, would burn more wood but can guarantee I wouldn't be dealing with these smoke smell issues.My least favorite time of year to be outdoors. Monday night I had water dripping off the snow pack on the roof, the rounds I was trying to split were frozen solid to the ground, and it was snowing.
I got all three pairs of work boots out, summer steel toe, winter heavy insulated and spring/boat/mud water tight. The only specialized foot gear I don't have out right now is snowshoes and chest waders.
And its warm enough my short chimney stack is working against me, dang +30s dF. Can't complain too loudly, I was burning 2000 gallons of oil annually pretty regular before I started burning wood, I have bought 609 gallons in the trailing twelve months.
I am thinking I will do the boiling vinegar thing on my cat this summer just to go into next season with the cleanest possible cat.
Correct in all comments. We removed the wash explanation 4 years ago because of the reasons listed earlier. 6-8 years will work fine for 80% of the owners. This group (Family here on Hearth.com) are not typical wood stove owners. Most have other things to doI've read many different posts that talk about this vinegar and water cleaning of the cat. That process isn't mentioned in our BKK manual. It says to use a soft brush and brush off the cat face if needed. It also says, "A nice hot fire will usually prove to be the best method of cleaning the combustor of deposits."
We turn our stove up to high at least once a day and let the cat temp get into the high temp range. Seems to be keeping everything clean. I personally would not want to take the cat out unless absolutely necessary. Maybe in a few years, we will have to do this vinegar and water wash?
So to clarify for the folks here with 3-4 yr old combustors that maybe approaching 12K hrs on them...
Would you recommend jeff_t carefully pickle the cat at this point?
I would not. I would look for other possible culprits to his observations. If the cat appears clean and not plugged, it's more likely another issue or two.So to clarify for the folks here with 3-4 yr old combustors that maybe approaching 12K hrs on them...
Sorry, Android manipulation error...years.Thank you Chris. 6-8 years or cords? I have no intention of removing the cat for cleaning or replacement until it really needs it.
Please elaborate.
Understand I have no complaint.
Probably lots of info on here about burn time. Personally, I got 30 hours on 2 yr old seasoned oak and hickory set to 1.5 on the tstat with my A30. It was definitely cold at that point but had a few hot coals in the ashes. Could have been better I feel if I had double wall as well. Heat loss from my single makes tstat open more to keep draft up and cat active thus burning load quicker. NEVER got anything more than 14 hrs with the old VC Encore, but then again, it was cracked...Tomorrow I will try to get a 24 hour burn with the fan and stove on low. Normally when the fan is running I reload every 12 hours.
Please elaborate.
My stack is still clean, I can tell that the performance isn't what it used to be though. Maybe I only notice since I typically burn my stove on a lower setting with no flames in the stove, now I notice the t-stat has to open more to create the same heat I used to get with a dark stove."
I'm with you, I load the stove with the cat hot or cold. I don't have the time or energy to worry about any of it. From an "inactive" cat I wait till it crosses the line into the active range then close the bypass, from a hot reload as soon as the wood is involved(not charred) I close the bypass. I'm not going to worry about replacing a 24x dollar cat every 4-6 seasons. That's why you'll never hear me complain how I feel my cat is getting tired during it's 4th season. I personally think I've done great burning the stove the way I want. Granted all my wood is seasoned(been on the 3 year + plan for a long time) and it's not covered with ice/snow/water when I toss it in the stove. Other than that I just burn the stove the way I need to keep the house warm.
Most of us on this site don't heat with wood because we "need" to, we do it because we want to. People who "need" to heat with wood can't afford fancy cat stoves, computers or internet.![]()
What do you guys do when you have lots of hot coals but not enough for a cold overnight burn and you want to go to bed?
Fill her up and go to bedWhat do you guys do when you have lots of hot coals but not enough for a cold overnight burn and you want to go to bed?
