First round of kiln dried wood made no difference.
Set it to the end of the normal zone at 2 1/4.
I did not take the top off. I do not think that is proper use of the stove.
It's cold in here.
Zanimal,
Thanks for trying out the kiln dried wood. That's one thing that can be ruled out......Ok so Its not the wood .
That helps a lot with trying to figure this out. The fact that you are getting stove pipe temps of 250 on dbl wall 20 inches above the stove shows that you are pulling gases good and getting an adequate draft like highbeam said. And if your flames went out after a time like you said at 2 1/4 stat setting and your pipe temps were holding 250 ? ,then your cat is working somewhat.
The fact that you can turn your stat down below 2 and the flames go out says to me that your bypass damper is closed..........Otherwise you would still be getting a lot of flame action....
And I saw the flames in your stove on post #548. Sorry I missed seeing that post
. Cause it also shows to me that your draft is just fine. Cause you were able to reignite your stalled half load in a couple of minutes. Its not the stack draft.
So I don't think its the Wood , the stack draft , or the bypass damper.
( Although I would check or have the damper checked first , just to make sure its closing right....Its an easy thing to check .)
That leaves two things........The T-stat and the Cat.
The fact that you can turn the T-stat down and it snuffs the fire tell me that yeah its working....But maybe only manually ......When you turn it down it does decrease the air but it is also supposed to open up to add air in the box to keep the wood burning which releases the gases from the wood and activates the Cat.
I Don't think this is happening right.. Something in the T-Stat is malfunctioning and or the air valve that lets air in the box to ignite the wood....Without this process the wood cannot get air and gas off to the cat.
This is the next thing I would do is have the T-stat checked and the air port that lets air into the stove. Actually I would ask the dealer to have BK replace it to rule out this possibility.
Highbeam mentioned that the Cat could be dead.........I think its possible but not until the T-stat is ruled out ....Cause a defective T-stat can make the Cat not function properly.
Highbeam , Yes the cat in the Ashford is stainless steel....It was also that way in my Chinook 30 . I have a theory on this about the cat thing. And that is that it might be possible that these stainless steel cats are not giving off as much heat as the ceramic cats that the princess and king models have.........I am assuming that rdust and Highbeam both have ceramic cats ?
I also have read by other members that the ceramic cats give off a lot more heat than the stainless steel cats.
Something to think about
P.S. I discovered that after removing my top cast plate from the stove, my house temp increased by 3 degrees In an hour and held that temp.......not sure why........well I do have a theory......heh
Allan
