After just over half of a cord burned, I am thrilled with this stove. It has exceeded my expectations for performance and the looks are even growing on me. The big difference that the family notices is the steady temperature, we only swing about 5 degrees in 24 hours where the non-cat created swings more than twice as big.
We've been able to travel, thanksgiving dinner, parties, etc. and return home the next day to a still burning stove and warm home. That's been a big improvement over non-cat craziness.
What am I going to do with all this wood?
Tired of the smoke spillage. I smoked the house out last night and again this morning. So I ordered a new appliance adapter without the damper installed. I need to make the chimney a better chimney than the house.
To be fair, this morning I loaded while running the fart fan in the bathroom and the house may have been under a vacuum as a result.
My theory is that you can use the minimum flue height but you need every bit of it and a key damper, even wide open, is still a restriction.
Anybody ever try and put cement in the collar before the appliance adapter to seal it even better?
I just found this thread and can't wait to read all the way through when I have some time....in the mean time can any of you answer the following:
I am almost ready to pull the trigger on a Blaze King Princess Insert. I have a Ranch style home with a walk out basement. I have a fireplace in the basement and on the main level. My question is: If I put this in the basement (approx. 1000 sq ft), will it heat the main level well enough that I don't have to use my other heat source, or should I put it on the main level (approx. 2000 sq ft.) and we would stay out of the basement for the winter months? There is an open staircase that goes down stairs that does not have a door if that helps.
Thanks....can't wait to "join the club!"
My thoughts-This has been an interesting and informative thread-and my first post. I don't mean to hijack this thread, but there seems to be several on here that know a lot about these Blaze King stoves with cats, so I need some help. I hope you don't mind.
I am wanting to do something different with my log cabin in the mountains. It has a ZC fireplace and one of those make believe chimneys. I tried installing one of those approved inserts and it works OK unless it gets too cold. I plan to eventually live there year round and know I must do something different before then. The cabin is at 9200 feet so we have both the cold, lots of snow and the high winds. It is a 8" cedar log, open cathedral ceiling with a open loft over half the house and only about a 1100 square foot footprint, but a lot of cubic feet to heat. Lots of windows. Descent insulation in the ceiling. Electric baseboard backup heat with a power cost of 15 cents KWH and would prefer to never use it.
I have looked at the outdoor wood boilers, soapstone, other heaters and have made up my mind to go with Blaze King. This thread has helped to verified my decision. I just don't know which one-the Princess or the King. The only choice I have is the fir, aspen, and other softwoods. I want to be able to use the top for cooking during power outages. We also want to have long burn times. We will have to either tear down and re-build a new chimney and have either one 90 or a couple of 45's, or just go straight up thru the cathedral area and thru the roof with a new metal pipe.
Any opinions on which model heater? Any help/advise is appreciated.
my new princess cat probe runs almost pegged all the time burning hardwoods seasoned 3-4 years. is this normal? i see some of you saying 1700*. my probe dosnt have numbers on it. is this ok or is somthing wrong? i'm getting 12-15 hour burns with the thermo in the normal zone. probally could get better if wood was the correct size. its all cut 20 inches for my deceased dutchwest neverburn.
I LOVE this new princess! 2 loads a day burning 24/7 and family is warm and toasty!!
My thoughts-
Plan on the King model. You can load that up and turn it down as you wish, and you won't cook yourself out of the cabin. I'm at '8200, but have twice the sq./ft. that I'm heating. At this elevation, burning softwood, I have no qualms about suggesting the King. But.....
Cooking, I'm sure you could. Keep in mind the wood will outgass quicker, and your CAT. temps will get to the upper limits before your stove top is as hot as you would like. EG- ST @ 550, Cat @ 1700 is a normal scenario for me. Sounds good, but you do not have much, in the the way of usable stove-top area to work with.
Kinda why I'm going to use the NC-13, it has it's place.
My thoughts-
I burn mainly fir and larch in my Chinook...and can very easily get 24+hr burns on full loads. The last couple of hours the stove top is at around 275 - but that's still good for shoulder season.Greetings BK Burners,
I think I have read here on the forum that burning soft wood or hard wood in a BK has very similar heat output with little variation in burn times. Have you found this to be the case in your experience burning in your units? I know with my non cat EPA unit I have a large variation in burn times based on the species of wood.
Thanks for your feedback. If this is not the proper place for this question let me know and I will post it elsewhere.
When using that blade, 1st spray with glass cleaner, slide the blade in one direction, do not scrape back and forth, use the blade once and throw it away. They dull and get burrs which will scratch the ceramic. I've owned a glass shop for the last 23 years. KenSpeaking of handles, my front door handle is very easy to close. It bottoms out with very little effort even though the door passed the dollar bill test four weeks ago. So how much effort is required to latch your front door and does the latch bottom out on the catch?
We are so warm outside in WA that I can't do full loads. I get a big kick out of rdust's photos since that is how I want to be burning this thing but it just gets too hot in the house. We are still in the 50 low to 60 high daily temp swings and rain. Just enough for a four split/12+ hour fire.
I emptied the ash during one of my warm periods and this stove holds a lot more than the heritage. Cripes, a couple inches of depth filled my ash can. No wasted chunks of coal or klinkers.
I've been "selling" this stove to my buds now. I expect to help install the insert model later this year to replace a homemade monster.
Oh and a straight razor blade is the cat's meow for removing the gunk on the glass. I tried ash on a wet paper towel, no dice, bought that rutland cleaner stuff, no dice, then busted out the brand new box blade blades and the stuff just scrapes right off. Needs to be a sharp blade and it goes fast. Even with a clean window, there's not much to see inside. The dirtiness is down low in the corners so you can still see the cat glow which is about all there is to see.
In the corners of the firebox I am getting the most awesome black tar creosote building up. Super glossy and thick but can barely dent it with my fingernail. Truly nasty stuff if I wanted to clean it or if it was in the flue.
Burn times will be similar, I find hardwoods give me more heat output. It's nice to know that I could still heat this place with wood people around here consider "junk" wood if I ever run into a hardwood dry spell.
So has anybody ever scratched their ceramic stove glass using the blade method?
