Is the freestander have a bigger box than the insert? my box size is 18" x 18", you guys seem to get more wood in when you load up.
It must be a little bigger, I'm pretty sure my box is 17x21"
Sounds like a long process?!
To put wood in I open the bypass, open the T Stat wide open, open the door, stir around the ashes/coals and put wood in. Close door, let it get burning well then close the bypass and turn the T Stat down. Takes usually 5-10 mins depending on how fast the new wood catches.
I leave the fan running all the time and I don't mess with the glass, stays clean enough on it's own.
It's been pretty cold here the last couple days, highs in the 20's and lows in the 10's and I've been burning 3/4 loads at #2 every 12 hours. So far the Princess has been keeping the house temps in the 70's without the help of the Keystone but my new 200 sq ft addition which is pretty much all glass is much cooler (60's). Looks like if it gets any colder I'll go back to 24 hour burns for the Princess to keep the basement warm and put the Keystone into 24/7 mode for the upstairs.
By the way the glass on the Princess runs clean at #2 for me. Sometimes I get a little brown on the lower corners but for the most part it's just as clean as my Keystone.
I had maybe 10 minutes to spare this morning with stove output dropping fast and a cold day ahead. I can start a new fire and warm up the cold house after work or do a big long reload ritual but none of my reload processes take 10 minutes so I had to let the fire go out. Aren't you supposed to let the new load rip for like 10 minutes to repel the moisture? I thought it would take 10 minutes just to load the frozen wood and get ignition, then another 10 to drive off any remaining moisture before the cat can be engaged. I read here that you guys are pretty much slamming the cat into action right away.
I don't load wet or frozen wood in my stove.
I think your box is deeper as well, theres no way I can go as long between cleaning out the ashes and I dont get as much as you do when I do clean it, I get maybe half a 5lb bucket when its full.Emptied the ashes last night as they had built up to about half of the eight of the stove's "belly". I couldn't fit all the ash into my bucket and had to leave some behind. I need to empty sooner or go and get a bigger bucket.
Emptied the ashes last night as they had built up to about half of the height of the stove's "belly". I couldn't fit all the ash into my bucket and had to leave some behind. I need to empty sooner or go and get a bigger bucket.
Despite strong draft in the cold weather, smoke spillage is still a problem when I open the door to reload.
To be clear, I'm using a standard galvanized bucket from the hardware store with the built in wire handle that I painted black. It is not a full 5 gallon bucket. I have noticed that this stove doesn't care about the ash bed, it runs the same with or without but I can fit more wood in without the ashes.
Try turning down the air south of 1 after cracking the door, it's a huge help for me but not sure if it will help others. Todd was going to try it but he never reported back(or I missed it) so I doubt it helped him.When it was warmer I stunk up the house pretty good a time or two. Good thing I only have to open the door once a day during the warmer weather.
>My neighbor, however, shuts the bypass on her Princess just as soon as she shuts the door on a reload, and she doesn't have any issues. She told me that's what it says to do on the sticker on the back of the stove. I haven't looked on mine to see what it says.<<<
I am on year number 4 on the BK, and this year have been loading the firebox w/o moving the t-stat to a warmer start level for a bigger start burn. Just keeping it where I want the temp. I am also only keeping the by-pass open when the door is open for reloads. Seems to be working fine, my house is nice and warm. I am planning on letting her go cold and check the cat. Also making an ajustment to the fan cover to see if I can get the rattle out of it....
BTW , I have a new cat on stand-by if this one goes bad....
Even at 20% MC or lower there still is water turning to steam.I've been doing 12 hour reloads and the last reload I just left it at #2, reloaded, bypassed for 10 minutes then engaged, worked just fine. Probably could of gotten away with engaging right away since I had a very large coal bed and cat was still way up in the active zone around 750.
So how do you empy the ash? I have to let it burn down to almost no red coals or I get flay ash flying all over the room. I think I have too much horizontal pipe that screws up the draft and if I don't open a window and be careful it's a mess. Good thing I have two stoves so I can let this thing burn down cold or I'd have fly ash dust every where!
So I try to leave the by pass open for at least 10 mins no matter what..but a lot of the times I don't.
I don't know if it's hard on the cat or not.
Chris at BK says a leaky door gasket is the thing that can kill a cat more then damp wood if I read his post right..I dunno.
Oh I tend to agree with everything you just said.The moisture, even at 20%, is deep within the large splits. 10 minutes won't boil it all dry anways so my theory is that the 10 minutes will get whatever surface moisture might be present from rain, bugs, or condensation and then the slowly released moisture will be consumed by the cat. Just imagine that full load of 12 splits and you know that there are logs or parts of logs in there that you can touch after 10 minutes. The inside is even colder. No way that the full load is going from 20 degrees to 212 in 10 minutes and if it did, you would see a major amount of water. 20% moisture in an 80 lb load is 16 lbs of water. Water weighs about 8 lbs per gallon. Do you think you can dump 2 gallons of water on that fire in 10 minutes without killing it? I compare this to peeing on a campfire, a pretty large amount of fluid.
Instead of moisture, do you think that the sudden blast of cold smoke from the fresh load could be shocking the cat element? The thing is cruising along happily eating 500 degree smoke and then wham, a blast of 100 degree smoke. A 400 degree difference on a piece of ceramic is like cold water on the boiling hot tea cup. I propose that during the 10 minute reload bypass session, the goal is to heat the smoke up. Moisture is not the issue.
the cool air coming in is what is hard on the cat?
