see the data on the masonry heater association site. Here is a place to start:
http://heatkit.com/html/lop-arc.htm
Hakusan said:Masonry heaters are the original wood gasification heater. They burn hot and fast (1300F or higher) transferring the heat to the masonry mass which slowly releases it. You can even build with a bake oven and hot-water coil to pull more advantage out of it. Other names for this type of stove are Kachelofen (with an umlaut over the o), tile stove as well as Russian, Siberian, Finnish, or Swedish stove/fireplace.
http://mha-net.org/
kuribo said:Hakusan said:Masonry heaters are the original wood gasification heater. They burn hot and fast (1300F or higher) transferring the heat to the masonry mass which slowly releases it. You can even build with a bake oven and hot-water coil to pull more advantage out of it. Other names for this type of stove are Kachelofen (with an umlaut over the o), tile stove as well as Russian, Siberian, Finnish, or Swedish stove/fireplace.
http://mha-net.org/
I have seen figures of 1500-2000F for firebox temps with 200-300F stack temps in some tests.... Without the pumps, plumbing, and storage losses, overall system efficiencies they have clear efficiency advantages over the current crop of boilers.
They aren't for everyone but for someone in the design stages of a new home whereby one can be integrated into the home, they have many advantages over any of the boilers including aesthetics, simplicity, longevity, and efficiency....
I can be convinced. Point me to the info or data that shows this and you will have me converted.
jebatty said:I can be convinced. Point me to the info or data that shows this and you will have me converted.
I didn't happen to spot info that showed operating temps in the 1800F+ gasification range, although logically this seems possible due to the fast burn rate against a masonry surface. I'm somewhat skeptical though, but only because gasification boilers use a high temperature ceramic gasification tunnel that can withstand these high temps for extended periods, and I didn't notice that masonry heaters use a similar material that can handle these very high temps.
Average net heat transfer is in the 60-65% range. Average particulate emissions were somewhat higher than EPA Phase II wood stoves. Average btuh output is in the 8K-10k range. Test were done with wood at about a consistent 20% MC. Wood burn is at a high rate with rich air supply and various long-path designs to capture the exhaust heat in the masonry before entering the flue. Exhaust flue temps were in the 300F-700F range. Heat captured in the masonry mass continues to radiate after the fire burns out.
There is no iron or steel sheeting to warp, crack, or burn through like you see in the E-Classic boiler or others. The entire firebox and flue channels are made of refractory which is what is used, though sparingly, in wood boilers.
20% is rather high moisture content. Heat transfer rates are typically around 20,000- to as much as 35,000 btu/hr with flue gas temps in the range of 300-400F.
SolarAndWood said:What is the biggest homemade storage out there? Is my 12 x 12 block room too big to insulate and line? Or are the advantages of pressurized so great that I should blow one of the walls out and put a few propane tanks in there? This is very feasible as I have 4 foot wide windows on the lower level.
Thanks again for all the great feedback.
pybyr said:if it is unpressurized storage with a liner, then the max. temp. your liner can handle will limit the max temp of the storage
if it is pressurized storage, then the max. temp. will be as high as you can comfortably run without risk of steam in the system
Gooserider said:it is really preferable to keep your BTU's stored as fuel, rather than as hot water because hot water doesn't "keep" very well compared to fuel...
Gooserider said:how many BTU's your boiler can put out during a single burn cycle, and base the size of the storage on how much it takes to store ALL the output of one burn, if you start at your minimum working temperature and the fire burns out as you hit the design max for the storage. This will give you your most efficient use in the summer when only making DHW. In the heating season, you might not get the storage to maximum without building two or more fires, but it will still have the desired "flywheel" function to make the boiler work efficiently...
Gooserider said:In terms of using your block wall room for storage, I would want to look very carefully at how the walls are constructed - storage sized volumes of water are very heavy and will exert major forces on the walls of the container, which MUST be designed to handle them. A standard construction block wall will NOT have been adequately built for this task... Foundation walls that have lots of dirt behind them for support will probably be OK, but a freestanding single layer wall probably would not be up to it, and the longer the unsupported wall length the weaker it will be... Blocks CAN be used to build a tank wall, but they require lots of rebar and filling all block spaces with concrete to reinforce them in order to do so.
Gooserider
Justburnit said:Hi Guys,
I haven't been on in awhile but this thread caught my eye. I have used a 5,000 gallon unpressurized storage two seasons now. As far as sealing the tank-room I used rubber membrane.
The lower part is one piece folded in the corners. The upper section is bonded all around. Best I can tell it works fine. This picture was taken early and the 2X4s are a temporary structure to support the membrane during construction.
Holy Guacamole, that’s a lot of storage! Could you share construction details about the outside walls? Perhaps some performance data or quality of life stories? Inquiring minds want to know.
Signature
Justburnit said:Holy Guacamole, that’s a lot of storage! Could you share construction details about the outside walls? Perhaps some performance data or quality of life stories? Inquiring minds want to know.
Signature
Yes I can, but I should start a separate thread about my system.
If I put 2’ of foam on top and 1’ on the sides and floor, I end up with 8’ D x 6’ W x 5’ H or something like 1800 gallons. I would have to replace the small section of block they removed and create a top hatch, but that seems pretty doable and I have a big headstart toward a decent size tank.
