Hello,
Thank you in advance for any assistance you can provide. We are building a home addition and want to have a wood burning supplemental heat option and just can't land the plane on what we want. We'd love to take advantage of the tax credit, but that leaves us with only the Astria Montecito Estate as a ZC fireplace. It's expensive (quoted $13,246 delivered w/ chimney, without install) and might be too big for the room, aesthetically. Our design has the fireplace/wood stove centered on the wall between a set of doors and windows (See below). Given the doors and windows, we'd like to keep our TV above the mantel in the 8' high room. We're also considering the Pacific Energy FP30 Arch (quoted about $9500 delivered w/chimney, not installed), but that doesn't qualify for the tax credit. From what I have read, the Montecito Estate requires the mantel to be no lower than 56" above the base, and the FP30 is 51-55" from base, depending on how deep the mantel is. 55-56" is about as high as we'd like to go for a mantel to be able to have room above for the size TV we'd like.
So, we're also looking at potential wood stoves and had the following questions:
1. Can a wood stove alcove be built to protrude out an exterior wall, allowing us to keep floor space in the room and have the stove pipe go up a chimney soffit on the exterior wall? Basically have the stove set back in the exterior wall and have the stove pipe behind the wall.
2. I haven't been able to find much information on the minimum height above a wood stove a mantel can be placed. I'm assuming this differs based on the stove, but when I've read some Lopi and Hearthstone manuals, it has been unclear. In the second screen shot, there is a measurement in a Blaze King manual for "J" - is that the height of a combustible mantle? Ceiling? Either? Is that somewhat standard (Blaze King had this at 37")?
We're trying to find the balance of cost, function, and keeping that TV above the fire and would appreciate any input from the experts here. IS there anything else we're not thinking of? We've looked at other options to move the stove, but it puts the chimney/pipe in a weird location outside as well. Thank you!
![Zero Clearance Fireplace vs Wood Stove in Alcove - New Construction Zero Clearance Fireplace vs Wood Stove in Alcove - New Construction](https://www.hearth.com/talk/data/attachments/291/291513-3396844c2c120cd51ecc3cddffbf01d5.jpg)
![Zero Clearance Fireplace vs Wood Stove in Alcove - New Construction Zero Clearance Fireplace vs Wood Stove in Alcove - New Construction](https://www.hearth.com/talk/data/attachments/291/291512-e15a4faba837d8aef0f2a1de31a5f91b.jpg)
