Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
If I can add my 2 cents. You will have many choices when it comes to a ZC. As many members mentioned here the best way to go is to look at the EPA units if providing serious heat to the house is a requirement since they are very efficient. However, one of the drawback is they typically have a smaller fire box than a strictly 'decorative' unit. And since they are EPA, you must operate them with the door closed to operate efficiently. However, it's not much of a drawback since most of them are designed to look beautiful anyway.
If serious heat and means of distributing it is of concerns. Many units offer a power vent kit where it can push up warm air to a room as far away as 50ft on some models. Some can be hooked up to a thermostat to control the powervent and you can program it depending on which room you put the thermostat in. There are also 'gravity kit' if you want to turn off the built in blower for quietness sake or to extract as much heat as possible. This kit takes ambient air from the room, distributes it around the ZC and exhausts the warm air through natural convention in vents above the fireplace (same room) or through ducts in room above. So there's lots of options. Think of your ZC as a beautiful furnace!
Finally, when it comes to your venting. You will not be able to use your masonry chimney. You will require an certified HT2100 chimney. Some MFG limits which venting MFG you can use on their units which may affect the overall cost. Others are certified on just about any brands of venting so you can shop around for best pricing. BTW, venting may cost you as much as the unit itself! Finally, Some will vent on a 10" flue, others 8" and 6". Obviously the 6" is much less expensive. So if budget is an issue this may limit your choices.
