jatoxico
I don't even know what it's supposed to look like and it looks bad
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
Not sure how familiar you are with the F12, but it sounds like you know the innards pretty well. The cover actually looked much better than I expected, as I had expected to find it knifed in half by the ridge in the rear burn plate, which holds that cover in place. That's what had happened to the cat chamber cover on both stoves, when I was running the Condar ceramic cat's with their problematic expanding gasket.Was the cat cover intact?
Wow, it sounds like you have gone above and beyond. Will be interesting to hear what Jotul says.Let the second Firelight go out today, so I could open, inspect, and rule out one cause of the failure. Found that one had a melted steel band around the cat, as well. This stove never displayed any super-high cat or outside temps, that I have seen, or even any sign of going hot (it's ultra-tame on such a short pipe).
We are back on 100% oil heat as of today. Cause of failure still undetermined. Plan is to rebuild one stove with parts I already have, and try to find a Jotul OEM cat to finish out this season. Calling Jotul tomorrow, to run these experiences by them, and get what feedback I can on this.
Brief history:
Fall 2011: Took ownership of first Firelight 12. Had original cat chamber, and I believe the original 19-year old OEM cat, which showed no physical signs of damage. Ran the stove in this configuration my first several months.
Winter 2012: Squirrel came down chimney, and destroyed refractory catalytic chamber. I replaced chamber and all other refractory components, and installed a new Condar SteelCat, which went from severely over-reactive at first to fairly mild over the remaining weeks of that season.
Summer 2012: Had insulated 6" liners installed in both my fireplaces, one on existing Firelight 12, and the other in anticipation of installing a second stove.
Fall 2012: Continued use of first Firelight with Condar SteelCat, now on an insulated liner. Acquired a second Firelight 12, and preparing for installation.
Winter 2013: Running two stoves, noticed new Firelight on 25 ft. chimney lit off much more easily than old Firelight on 15 ft. chimney. Eventually, started having problems with both stoves lighting off.
Summer 2013: Found both Condar SteelCats severely deformed. Spoke with Condar tech, who said they've had an almost 100% failure rate of those cats in downdraft stoves (i.e. Jotul, VC).
Fall 2013: Replaced both Condar SteelCats with Condar ceramic cats. Had concerns over Condar's advertised expanding gasket, but Condar tech assured me this cat model did not have an expanding gasket.
Winter 2014: Ran both stoves entire 2013 / 2014 season on Condar ceramic cats with no apparent troubles, aside from running out of wood before the season was done. Life was good.
Summer 2014: Discovered the gasket on both Condar ceramic cats had expanded (as advertised!), and broken the refractory cat chamber cover on both stoves.
Fall 2014: Replaced both Condar ceramic cat's with Applied Ceramics cat's, and replaced both cat chamber covers. Both chambers showed signs of stress where Condar cat's had pushed into them, but no obvious breakage / complete failure.
Winter 2015: Found both Applied Ceramic cat's severely damaged due to high heat.
Ideas?
Depends on the tech. One of their senior tech's is very good about answering any and all questions, and is actually quite a fan of the old Firelight 12.Jotul will say "Yawn. 20 year old stoves.".
Soooo... any thoughts about a new stove? I would love to see a BK Princess in that fireplace![]()
Backroom conversations on that very subject began earlier this evening. This will completely blow my cover, in my wife's eyes, of this wood heating thing being any sort of "money saving" operation.Given the period of the house the only option I suspect would be the BK Ashford.
