Straight out 24", a clean out Tee, straight up 60", termination spout.once the exhaust enters the wall thimble what happens? What is after this? No mention of anything about the exhaust.
Eric
Eric
The original post states clearly, all vents and passages are clean and clear!! already look, did that firstThat is where the ashpan is covered. The door seals tight against that. I will be playing my bet on what happens after the pipe goes through the wall thimble. No one has said anything about the vent being plugged at the cap or liner or whatever since we do not know. GI Joe said, "Knowing is half the battle!". We don't know.
Eric
Spot on, the gasket for the ash pan is not making contact on the upper left side, looks as though it has come unglued.For crying out load folks https://www.hearth.com/talk/attachments/20150128_071336-jpg.151919/ should tell you all you need to know.
What you see is the excess that I spreaded around, the silicone was applied in the cavity then inserted onto the tail pipe of the stove, waited 24 hours for drying then completed the rest.https://www.hearth.com/talk/threads/xxv-troubles.140117/
This is not you problem bu you have the incorrect components in the system. That is not the correct adapter and in my experience silicone works better inside the seams and not outside.
Eric
No no, that is excess gasket material, anyone with an XXV could chime in on that. The XXV has 2 doors, the main on on hinges and the ash pan door on a cable, the main door closes over top of the ash pan door.Spot on, the gasket for the ash pan is not making contact on the upper left side, looks as though it has come unglued.
I did chime in!No no, that is excess gasket material, anyone with an XXV could chime in on that. The XXV has 2 doors, the main on on hinges and the ash pan door on a cable, the main door closes over top of the ash pan door.
Did not try that, but my home is extremely air tight, not an option. In Canada these homes are known as R2000 homes, that is why I have only burnt 1 ton between 2 stoves to date.How does the stove run with the tee cap off and the OAK disconnected? This might be a shocker but the XXV I have in my house does not have an OAK. Two of the stoves that burn in my store do not have an OAK. I only have one WT in my store with an OAK and there is no pipe connecting it to the stove at this time.
Eric
Ok, then the piece of gasket is attached to what? pic?I did chime in!
Eric
That is normal in that picture. I would do the dollar bill or Euro (Canada HAHA) test and make sure your doors are sealing correctly.Ok, then the piece of gasket is attached to what? pic?
LOL...dont have dollars bills here, its a coin!! Have to use a 5That is normal in that picture. I would do the dollar bill or Euro (Canada HAHA) test and make sure your doors are sealing correctly.
Eric
Eric
When you say clean totally, scraping and brushing and vaccum, or use some kind of cleaning agent?Draft tests on a cold box are fine and dandy if the stove doesn't expand and cause gaskets to part company with the metal of the stove.
Loose ends can sink a seal if they get where they shouldn't
Pellets embedded where there is a gasket is a problem as well.
Gaskets are where they are for a reason , to keep what is going on on one side isolated from the other.
Mr. Bear hasn't any real insight just pointing out where I'd start.
But on the other hand 'sote is a very bad thing and needs to be totally cleaned out if at all possible prior to restarting a stove.
I can make a mess of my bucket of parts just by not closing and latching the door fully
LOL...ok did that, I mean you can still tell something happened, but it's clean and the rest will dry and burn off.Elbow greaseYes , good old fashion brushing and scraping in case the Yankee slang is not very clear
When in operation does the stove ever really get up to a good hot heat inside the firebox or does it tend to have a low fire and just sort of smoulder? It sounds like it doesn't take much heat from the stove to keep your place warm from the pellet usage.Did not try that, but my home is extremely air tight, not an option. In Canada these homes are known as R2000 homes, that is why I have only burnt 1 ton between 2 stoves to date.
If you can get the stove outside a good old fashioned sponge bath using warm water with some liquid dish detergent, you need to keep the liquid away from the wiring and electronics. However the use of elbow grease and scrappers also works. The warm water and dish detergent loosens the crud up however it also makes one he double l of a mess.
One other thing that has gotten into the act in the past with some stoves is the back-draft damper they can and do stick in other than the desired position.
