There was a dead White Ash down by the "lake" as they call it here. In WI, it's a pond.  😏
Anyway, it's been dead for quite a few years, and just from the look of it I figured it would be pretty well shot. It finally fell a couple months ago and blocked the path so I sawed it to be able to get the quad through. The first few cuts were pretty punky but then to my surprise it started looking better as I made a few more cuts, working toward the top. I bucked the rest today. It was looking pretty good until I got to a fork. The smaller branch of the fork, which I think died before the rest of the tree, was kinda light, but still solid wood. You see it in the front of the trailer, small half-rounds.
I had to dodge a little rain, but got all the good-looking rounds split and hauled up to the big trailer, two quad trailer loads heaped up pretty good. I'll check the six or so rounds I left down there, to see if there's anything worth keeping.
I used the pickaroon for the first time in earnest, and it's pretty handy. You can sink the tip into a split and pick it up, or just use it as lifting tool so you don't have to bend as far to grab the split. Also nice for setting half rounds or whatever back to vertical if you need to split em a few more times. I also used the punky lower rounds as a backstop, and that kept a lot of stuff vertical..I'll have to use that trick more often.
Most of the splits were pretty solid, but that stuff is
 sopping wet! Maybe soaked up more water since it was growing right next to the lake?
A couple years ago I got another White Ash that had been dead standing at least five years, and although not as sopping as this one, it was testing 30%. I foolishly didn't check it after one year stacked to see how quickly it was drying, just let it go for two years.
Now I'm having to gamble that this stuff will dry all the way in one summer. I'm putting it in a SIL's metal frame and roof shed, walls covered on three sides by canvas but gable ends and front open for some air flow. There's not a lot of wind since she's down a valley a ways, but at least the open side is pointing toward the prevailing wind. But her house is close, somewhat blocking that air movement.
So has anyone had experience drying this Ash that's been dead a long time, but is still wet and heavy when cut? I'm talking White Ash here, not Green or Black which I assume dries faster since it is a lighter, lower-BTU wood than White.
I may re-split some of the bigger splits as I stack it, to enhance drying. But I'm hoping this long-dead stuff just has "free moisture," that will dry faster than the bound moisture of a tree that was cut when still living. Also hoping for a hot, dry summer.  😏
Here's today's haul--looks like mostly meat!
![[Hearth.com] Work Done 2023 [Hearth.com] Work Done 2023](https://www.hearth.com/talk/data/attachments/309/309768-d50f0bbcaabdcf128f9b31f19e0962c2.jpg?hash=5lL3mFB9ku)
![[Hearth.com] Work Done 2023 [Hearth.com] Work Done 2023](https://www.hearth.com/talk/data/attachments/309/309767-09af24f57870ec3ba1a1b6d24d96f932.jpg?hash=wjG9CTeF3U)
![[Hearth.com] Work Done 2023 [Hearth.com] Work Done 2023](https://www.hearth.com/talk/data/attachments/309/309766-3a6c48bbfc4cbcd6c9c91a028d539541.jpg?hash=tD9VQBtePx)
![[Hearth.com] Work Done 2023 [Hearth.com] Work Done 2023](https://www.hearth.com/talk/data/attachments/309/309765-9139b898632ea316ad09a88dbc2991f1.jpg?hash=lZodo8AcUc)
