Right, that's all I'm saying; If someone needs a lot of heat, probably the case in Wyoming with 4000 sq.ft, begreen and I are saying that with the same stove in the same house, we've found you can pull off more heat faster with the blower. That said, all stoves are a combination of radiant and convective heat, so the differences might not be as cut-and-dried as some might think.
South East, huh? Like Georgia or something? You could probably heat your place with two candles and a fart.
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
The alcove stone would absorb some radiant heat, and a small fan on the floor some distance in front of the PH might help get more air heated. I wouldn't want a radiant stove like the PH in an alcove, but since the stone is inside, not an exterior chimney like I have, the heat is going to end up inside the envelope. Looking at the EPA numbers on the Ashford, output is rated about like my little Dutchwest 2460. That ain't gonna do much damage in 4000 sq.ft. If you're going with two stoves, I might consider an Ashford as one of them. One stove only? Get something that will throw down some serious heat to make it worth the effort. JMO.
