Or 6" to the corner with a double wall pipe, as I read it.Am I reading the specs correctly? Englander 17-VL only 7" clearance, unit to corner. Whereas Morso 1410 is 14"?
Yes indeed. But still 14" for Morso ...... ?Or 6" to the corner with a double wall pipe, as I read it.
Wood supply will be your biggest problem. Wood that is purchased now will almost certainly not be dry enough to burn, no matter what the supplier tells you. Depending on species, it can take from a year to three years to season properly after being cut split and stacked.Wow thanks I had no idea! Should I cover the wood?
Link doesn't work, looks like it's http://www.graystove.com/ now ... That looks like a decent little stove! 14x14", 8000 BTU/hr, uses pellet vent for a flue (would have to send it vertical though since it's a woodstove, can't just vent out the side) Perfect shoulder-season burner for some of us I bet (echoing Dick Hill's advice about having a small stove and a large stove for efficiency), and it has non-catalytic burn tech. They have a stand premade for it so it sits up high.graystoveworks.com
no affil
