Over the past day or two I've been PM'ing with another forum member about his Masonry heater. I'm facinated with those things, and I wish my house would support an install of one since they are the ultimate wood heating appliance as far as safety and efficiency.
That said, a point that dawned on me during the exchange and pointed out by that member is the issue of cost and return when weighed against other things in life. A basic ROI (Return On Investment) seemed like a good topic to float since I'm sure there are plenty of folks lurking who are trying to decide if they should drop 2 grand on a stove and another 2 grand on chimney work and install.
So to put this in perspective, I'm going to use extreme numbers, and if the numbers folks are really dealing with are less, then decisions should be even easier.
Let's use this from one of the Masonry heater websites:
Heater Core: ~ 5000 for the core.
Shipping: ~ 500
Facing and chimney work: ~ 5000
Total: 10,500
As far as masonry heaters are concerned, I'd bet that's actually conservative.
So, If installed in a new home, 10,500 is around 3% of the total cost assuming the home cost 300,000. - Almost at the noise level, and if the home were to have a masonry fireplace anyway, the increase would be more like 1.5% of total cost.
When weighed against heating that (I'm going to use 2500 sqft) home for a single year, the approximate cost would be:
800 gallons of oil at 2.80 (my lockin price for this year) for a total of 2240.
Now I'm also assuming the wood is free. ROI is significantly longer if your buying your wood.
That gives a return on investment of 2 -4 years depending on assumptions.
Also, consider if a person were to take a skiing vacation to Aspen. That could easily cost a family of 4 around 5000 dollars. Take a year off and you've at least paid for a heater core.
Weight this against buying a Mercedes C280 for 34k vs a Dodge Stratus for 24k. Hmm, paid for the heater in one shot, and that's regardless of how you get your wood.
Now, do all this same math with a wood stove and the numbers get better. I'm sure some of the folks here will start digging into my assumptions since they are not very precise, but the point I'm trying to make here is that if you look at the big picture and weigh spending X amount of dollars on a wood heater vs other things you spend money on, the wood heater just might be pretty easy to stomach.
(Let the assumption bashing begin)
Shipping: ~ 500
Total: 10,500
