No city water here - draw directly from the lake. We're on a piece of bedrock but ran the line along an area where it drops off and back filled but can't remember the depth. 1-1/2" line with internal heat trace inside 6" pipe with expanded foam. Back to the drawing board...
None here either that is why the well line is well below the "frost" line by several feet.
Neighbor has a water line in his barn and that is well wrapped and has heat tape.
My poor chickens with the water heater even had problems on more than a few occasions, luckily I only had to break the ring around the outside and remove one section. The heater works just fine until the temperature gets down below -10 F.
If I could get NG on this lot I'd have it already, used to have it in the big city. Nearest location is too far away.
So wood pellets it is (got to have something the boss can handle). While I have the time wood is just too time consuming, would rather spend it playing in the garden.
Now I best find out what it is that has my stove not feeding correctly. I'm waiting for it to cool off so I can finish emptying the hopper, I suspect I have a bed of fines that the auger is just tunneling through instead of moving along causing a feed volume reduction.
