O
oldspark said:Its funny how something so simple and obvious can be so elusive to some.
Kilks said:I am not certain about the validity of the arguments presented on this site, but I had remembered reading this before and dug it up again when I saw this thread.
It is information from (broken link removed to http://www.chimneysweeponline.com/howetwd2.htm)
Wood that has been seasoned for 9-12 months still contains about 20-25% moisture, most of which is wood resins. These resins play an important part in the three stages of wood combustion. During Stage 1, the kindling fire warms up the fresh load of wood and any remaining water content is removed by evaporation and vaporization. As the wood reaches 500 degrees or so (Stage 2), the resins begin to break down chemically, and volatile gases are released which squirt out through the wood fiber and ignite, boosting the temperature of the fire to around 1,100 degrees and producing 50-60% of the heat value from that load of wood. As the gases burn away, the flames finally attack the wood fiber itself (Stage 3), and extract the remaining heat value through the process known as charcoaling.
If your firewood has dried to the point where it has lost its resin content, your fire will go directly from Stage 1 (warming up to combustion temperature) to Stage 3 (charcoaling), skipping Stage 2 and missing out on 50-60% of the heat (and burn time) you'd expect to get from that load of wood. Here's what the US Dept. of Energy website has to say about too-dry fuelwood:
"Some well-seasoned wood can in fact be too dry for today's airtight stoves. If you place wood that is too dry on a bed of coals, it will instantly give up its gases as smoke, wasting unburned smoke and producing creosote buildup."
Stump_Branch said:I am of the belief that if one extreme is equal to its opposite. meaning, if too wet wood is bad then too dry probably has its pitfalls as well. now that being said hold on. im saying that ranking and stoeing wood outdoors with sun and air for however long, that wood isnt going to get "too dry". mostly because of the environment its in, won allow that. ah the environment now we are on to something. if its kiln dryed or allowed to dry out in something of a 'controlled' environment, then I COULD see the chemical composition changing to produce more 'evil toxins', possibly a fire hazard as the super dry wood could be an uncontrollable fire whatever crap they selling. I know I know Malarkey you say. but when it comes to a one side of the fence or the other...I think ill be someplace in the middle. (or 20% ish in this case)
All good things in life take time. Why wouldnt the same be true for wood?
My guess is you would have to go out of your way, use some sort of energy source, whatever, to make wood 'too dry'.
woodchip said:There is one other issue to look at.
When designing a wood stove now, would someone deliberately produce one that burns wood at 1% m/c better than 15%?
If most people dry wood to 15 - 20%, would the manufacturers not make stoves that burn wood most efficiently in this range.
Note, this is merely a comment for thought, and not a serious belief.
As I see it any moisture means boiling water and steam in the stove hindering the secondary combustion and the lower m/c, the better, as long as the stove is in good condition and has airtight seals when dialled down![]()
Backwoods Savage said:Today's stoves are not the air-tight stoves. This is just one more case of some dummy putting into print something they have read in the past and just pass it along, ignorant of what today's stoves really are like.
ruth140 said:i still want to know what the original complaint say to Woodstock that they answered with "your wood is too dry".
was it running too hot, was it running to cold...was the inside of it warped, was there a crack in the stove?? i mean what was the problem?
Just wonderin'![]()
Kilks said:Backwoods Savage said:Today's stoves are not the air-tight stoves. This is just one more case of some dummy putting into print something they have read in the past and just pass it along, ignorant of what today's stoves really are like.
Hi there and excuse the ignorance, but I am new to the game (3 years burning) and have been using an old stove from the late 70's or early 80's so I am not as familiar with all of the new stove designs. I am assuming that the quick release of gas would not be wasted in a newer stove because of the cat which will efficiently trap and burn this gas? I know that in general my stove is probably not very efficient, but would burning wood in the say <10% mc range be even worse for my air-tight stove? Once again, excuse the ignorance if this doesn't make any sense at all! 8-/
