Wood I.D. This wood is the same color as a carat?
Monkey Wrench
304
On The Farm
No Pics.
Cut a small section out of a tree lying on a steep incline. No bark and in a bad spot so I just for no reason cut a 18" section out of it last year split and stacked with this years wood. Today put it into the insert. Started like oak, but throws out MORE heat...Lots more? The best way to describe it same color as a carrot? When the snow stops I'm fetching the rest of it. Any Ideas?
Stay Safe.
Hedge or also known as Osage Orange
Without seeing it I'd guess either Black Locust,Mulberry or Osage Orange (hedge) going by your description.With pics we could tell more.
I would bet hedge too.
I'll get pictures up when wife returns from work. This wood burns like a brick, keeps going and going. 4 hrs and stihl throwing off heat. I feal like posting an armed guard around that tree?! Google-ing hedge... Thanx For The Info.
Frank
The most orange woods in the east are Hedge and Mulberry. both are great firewood. hedge is supposed to be significantly higher in BTus than oak, Mulberry about the same as oak, so maybe you have hedge.
This wood was cut and split last year. Hedge and Mulberry both would be orange by now.
I've never seen hedge but I thought my split and aged Mulberry was grey. I have to go take a look. I never really payed attention the seasoned color of it.
Adios Pantalones said:
Hedge is sometimes orange, but more often yellow-yellow when just split/cut. Black locust is a more sickly pale color.
Hedge is bright yellow when fresh cut/split but turns to a burnt orange color after a while.
Locust, from my experience is a pale greenish yellow color but after cut/split for a while it turns to a light burnt orange color (but not nearly as dark as hedge does).
From the sound of it you have some hedge. If you have another piece of it then cut it alittle; if it's bright yellow in the fresh cut it's hedge.
My pics don't do the orange color justice, but I had/have what may be the same thing as you do. can't tell you how mine burns because I wanted an ID before I destroy the evidence. I've burnt a couple of splits, but not a stove load yet. Carrot describes it well.
https://www.hearth.com/econtent/index.php/forums/viewthread/63398/
That looks more like a black locust to me ... but not positive...
Without seeing pics i would guess hedge or mulberry. I have never cut or Burnedt hedge but I have a good bit of mulberry and after it dries it turns like burnt orange and both are dense woods that throw a ton of heat.
Here is a picture of Cherry. And Red Pine I think is also red on the inside, but I'm not sure how it drys.
  • Wood I.D. This wood is the same color as a carat?
