With your budget you could easily remove and replace a few walls. Are your basement ceilings tall enough? If so, I'd reach out to a local contractor and get a quote on the construction required. Might be a lot cheaper and easier than you may think. Great excuse to replace that slider with something bigger and more "grand". ha.
Thanks, that's something to consider. I wrote-off the Garn because of the expense of creating acess for it.
I live in Los Angeles (For another 8-9 months, anyway). Everything is expensive here. Hopefully Vermont will cost less.
I take it that you believe that the expense of construction- changing the sliding door and interior door way to accommodate the Garn, might be comparable in price to installing a gasification boiler and water storage system?
