How much power did they require? Would you be able to run this off a small solar grid?I had a barrel strap heater that I could switch to on cloudy days or longer cloudy periods to keep the water warm.
I had it hooked up to a regular outlet. Not sure how much power it drew.How much power did they require? Would you be able to run this off a small solar grid?
Yeah, I remember he went out a ways, but he’s trying to grow citrus, lol. I imagine you could get by with a lot less if you only wanted to warm it enough to grow kale.I remember watching this video a few years ago. If I remember correctly, he ran the thermal heating tubes all over his property, not just under the greenhouse. To get the length of tubing he has buried as deep as he did, you would pay a lot for the excavation and tubing, but what a great greenhouse!
He buried 7, 8" tubes, 8feet deep and 90 feet in length from what I can tell in the section where he talks about them.Yeah, I remember he went out a ways, but he’s trying to grow citrus, lol. I imagine you could get by with a lot less if you only wanted to warm it enough to grow kale.
I imagine you could rent a mini excavator and do the digging yourself. We’d only have to dig 4 feet or so down here. Do they have trenchers that go down that far? That’d probably be faster as the trench only has to be wide enough to drop in hose.
					greenhouseinthesnow.com
				With that weight, I'd collapse too!I just read online that Russ Finch's greenhouse (that greenhouse in Nebraska growing oranges with the extensive underground piping network mentioned above with video) collapsed under the estimated weight of 195,000 pounds of snow on the morning of December 15th, during a blizzard.
Greenhouse in the Snow | Geothermal 4-Season Greenhouse | 1114 W 2nd St, Alliance, NE, USA
Greenhouse in the Snow manufactures geothermal, 4-season greenhouse kits as well as other 3-season greenhouse kits. We also manufacture many additional accessories to customize your greenhouse! Located in Alliance, NE. Made in the USA.greenhouseinthesnow.com
Growing on up the plains I remember a blizzard so bad our 2 axel 8x8 tractors could not get through the drifts. To get my aunt to town a cat dozer was found and it could not push through some of it so it used the blade to to dig it out backwards.I just read online that Russ Finch's greenhouse (that greenhouse in Nebraska growing oranges with the extensive underground piping network mentioned above with video) collapsed under the estimated weight of 195,000 pounds of snow on the morning of December 15th, during a blizzard.
That’s a shame. He must be 90 years old. That’s a literal dream crusher. He proved his theories in my mind.I just read online that Russ Finch's greenhouse (that greenhouse in Nebraska growing oranges with the extensive underground piping network mentioned above with video) collapsed under the estimated weight of 195,000 pounds of snow on the morning of December 15th, during a blizzard.
					smallfarms.cornell.edu
					www.gardeningknowhow.com
				A well-managed compost system can be used for winter greenhouse heat.
Any one have pond or pool that doesn’t freeze solid? We don’t need tropical heat just enough for the really cold nights. We run the pool pump during the freezing weather. Stays about 50-55F.If you have loads of compost, this will work. You need a lot of compost to heat a greenhouse of any size other than a very small greenhouse, and you need a lot of material "in the wings" for when the pile of compost stops cooking and loses its temp.
Maybe you could make a couple of cold frames out of old materials. Cold frames might come in handy sometime.
What temp did you go with,I actually wrote the above post a few hours ago, but forgot to hit "Post Reply". I just came back and it was still here.
Well, anyway, in the past hour, I decided to go ahead and order a case of the phase change material to test in my present greenhouse. The box is 9 tiles for a total of 36 square feet. I took advantage of their 10% off, so the box cost $157.50 instead of $175. Using it for a while in my old greenhouse will help me decide if I want to order more tiles for my new greenhouse.
