smwilliamson said:I can just imagine an apartment complex in the projects having 30 of these units running on one broad side of the building and the entire facade being black.
dac122 said:I think this unit needs a nice yellow emboldened sticker on the side that says, "In the event of hopper fire, open window and push".![]()
magsf11 said:just looked at the web site and found the clearances( Clearance from Side Wall (in.) 2
Clearance from Corner (in.) 6 ). thinking to myself if you have vinyl windows it might melt the window or if you have wood it might just start to smoke?
its ul tested/listed & probly has mounting hardwaretinkabranc said:magsf11 said:just looked at the web site and found the clearances( Clearance from Side Wall (in.) 2
Was thinking the same thing. How much heat and weight could a vinyl window take?
smoke show said:if that loads from the inside it'll be perfect for my garage.
yep prolly a good thing my garage ain't on the second floorslls said:smoke show said:if that loads from the inside it'll be perfect for my garage.
It would be hard to load on the second story.
pelletdude said:Yes they are UL approved and can be used in an RV, Mobile Home or a small apartment. Retail is $1,799.00 at our Stoveshop. They put out good heat and no chimney is required. I think there will be quite a few folks that will find applications for them.
blaster668 said:It is made by US Stove, but oddly I could not find it on their website.
wrong, UL testing & listing certifies that unit is safe when installed & operated per directions which is the first thing the code inspector wants to see, which is what the ins. co. wants to hear.Nicholas440 said:That is just plain crazy... Someone is always trying to figure out a way to make a buck... Try telling your insurance company you put live fire in your window opening.. Thats nuts.
Safety wise, and code wise look at all you have to do to install one normally in a room. The thing is not do they work, Im sure they do fire up and put out heat.. The thing is all the jerks that will buy them and put them in a window opening who have no clue about Fire Safety. It doesnt take much to put a UL approval on an appliance either. UL ratings do not guarantee the unit is totally safe, it says that it worked .
smwilliamson said:dunno if anyone posted a vid yet...not going to read through just to check.
here ya go.
http://smdistributing.com/S&M_Distributing_Co./ashley.html
