Pressurized 'design' takes hot water from boiler and sends it to top of storage. Loads then draw from top of storage. If there is hot water to be had then loads will get it as soon as you please. With pressurized storage this 'design' is as simple as appreciating that hot water rises.house taking priority over storage has everything to do with design and nothing to do with pressurized vs. unpressurized.
With non-pressurized it's a whole different ballgame, which has everything to do with the fundamental differences between the two types of storage.
and water is pumped through a flat plate to the top of the tank and obviously returns from the bottom. My distribution water enters the bottom of two parallel 100 foot coils and exits the top to the zones. The coil starts absorbing heat from the cooler storage water on the bottom of the tank and gets progressively hotter as it proceeds to the top and subsequently out to the zones. When the system is idle (ie, no heating, no zones calling) The storage water stratifies as it would in any tank. The only difference I see and experience is the ability of the coil to absorb the maximum temperature of the top of the tank which really only makes a difference when the storage temperature is down to levels that are marginal for the load.
![[Hearth.com] Will My Current Baseboard Emitters Work Well With Gasifier and Storage? [Hearth.com] Will My Current Baseboard Emitters Work Well With Gasifier and Storage?](https://www.hearth.com/talk/data/attachments/129/129006-31ee849a418eeb40fe2d5c73e3b88792.jpg?hash=PTU-66AL1T)
![[Hearth.com] Will My Current Baseboard Emitters Work Well With Gasifier and Storage? [Hearth.com] Will My Current Baseboard Emitters Work Well With Gasifier and Storage?](https://www.hearth.com/talk/data/attachments/129/129007-6dc5d8ad086b1d8aa00c6363e5b255b3.jpg?hash=-QG0pT7d-X)
