I think my reasoning stands; If jacketing keeps the box hotter, more heat is going up the flue, unless that heat is moved into the room by a blower. I just mentioned it as an aside to begreen's post about his cast iron jacket evening out the temp swing vs. a radiant stove. I wasn't saying that jacketing was somehow bad, only that it can impact the delivery of heat to the room vs. up the flue, unless a blower is used to counter that. I figured I would throw that out there since this has turned into just another cat vs. non-cat thread.
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
You saw an extreme example of the effect of jacketing with the Princess, where they also have jackets
inside the box, and the stove on high can't match the heat delivered to the room by your Regency.
I actually have a bit of jacketing on my stove, a rear heat shield I added to keep radiation from being absorbed by my exterior masonry fireplace and chimney. There's no blower though, so I think some amount of the heat kept in the box is going up the flue.
How much heat is actually lost up the stack due to jacketing with no blower, I don't know. But as I said, I can swing open the trivets on the T5 and see the stove top temp drop 50 degrees. And the trivets aren't even solid, they are more of a grill, but still hold that much heat in the box. I
will get the blower for my SIL's T5 soon..
Yep, my BIL's basement stove, a '79 VC Resolute III, has a thermostat.
The main advantage I can see is that when the stove is in the coaling stage, the thermo will open and fire up the coals to keep the output up a bit, if no one is home to manually do that when needed. On my stove, I don't see a
huge difference when opening the air on the coals, but it is appreciable. It will keep the stove top up around 300 for several hours, as opposed to the stove top drifting down to 250, then 200, over a longer period of hours.
When firing up the coal bed in my stove, the stove top holds at 300, and the sides also warm up more from the radiation directly hitting them. In a BK with internal shielding, maybe the warming of the side walls wouldn't be as pronounced, I don't know.
In average weather, even with my leaky house and suspect insulation, I don't often open the air on the coals since room temp remains within a couple degrees regardless.
Bottom line, grated ash-handling and other features were
way higher on my list of priorities than having a thermostat was. It strikes me as just another red herring, like the chimney-clogging, no-heat-output low burn.
