My Regency Ci2700 was installed in January of 2020. My wood is split, stacked, covered and off the ground. Moisture content is below 20%. Readings are taken on fresh splits with the pins running parallel to the grain after the wood has been in the attached garage for at least 24 hours. I have 2 moisture meters.
Last year the Installer claimed it was the wood. That could have true in early 2020 when I purchased a half cord that wasn’t the best. I’m still picking through that load. Suspect pieces go through a kindling cracker and if they feel too soft they get tossed.
The 20-21 season I burned mostly ash that I got from my neighbors when he cut his tree down in the spring of 2020. Moisture content when burning that was under 20%.
This year I’m burning wood I acquired in 2020. Mostly ash and maple, some black walnut, some unknown. It is all from rounds I split stacked and covered. Moisture content has been below 16%.
I’m constantly getting soot on the right side. Starts in the lower right and works it’s way up about 2/3rds. Most times it’s sticky and harder to clean. Something I do get soot on the left side, but it burns off or it is easy to clean.
I clean the glass with either Rutland’s glass cleaner or a damp paper towel and ash. I have no problems lighting a fire. I use the top down method. I kept the door cracked until it’s burning good, prob temp is in the 300-400 degree range. Cat is engage above 500, usually closer to 600 degrees.
When I close the door, the fire box gets smokier but clears up pretty quick. When I close the bypass, the same thing happens. The air control appears to work as it should. I usually leave it fully open or slightly closed. The door passes the paper test.
The flue is about 20 feet tall. The cap is not clogged. I inspect the cat and it always looks clean. The installer cleaned and checked everything out after the 20-21 season. He said everything looked good, and there were no issues.
I do notice that the flames appear to lick the glass way more often on the right side. And it appears the secondaries sometimes seem to move left to right in the back of the box. It’s as if sometimes there is a slight clock wise rotation inside the box.
I also noticed when using an infrared thermometer, the right side is hotter. Tonight it’s running 20 to 40 degrees hotter.
Is this just the way it goes or is there something I can do about it.
![Why do I get so much soot on the right side of my glass? Why do I get so much soot on the right side of my glass?](https://www.hearth.com/talk/data/attachments/291/291550-27b0a28a5f58a4cc15ca3b5fd37666af.jpg)
