M
MasterMech
Guest
I only intend to buy one saw, and no money has been spent yet. If you were looking to split logs, not necessarily drop trees, exactly what saw would you buy? Money is not the limiting factor, although I am not looking to go overboard. I want to know I got the perfect saw for what I need and I will never be tempted to upgrade. $100 today is better than buying a second saw later. I keep the things I buy a long time and take very good care of them. Quality doesn't need to be replaced saving money in the end.
I wouldn't even be looking at a MS290 then. (That saw is the definition of "compromise".) Maybe a MS391 with a 20" bar or as others have said, go pro, MS362 - 20". If you think you can use most of a 20" bar more than just occasionally, I would not recommend setting up the MS290 with a 20" bar, regardless of .325" or 3/8" pitch chain.
For just bucking logs I'd definitely consider the average diameter of the logs you cut. If they rarely exceed 16" then 16" bars will work just fine. But there's something to be said for making 1 cut through the log on 80-90% of what you cut as opposed to often having to make a cut from each side of the log.
