What's An Approximate Number of Tons Use for a Year in the Northeast?
I'm just fooling around with numbers, thinking about a pellet boiler. Since I buy logs, the raw material might be half of pellets. Pellet stoves, and I imagine even more so pellet boilers, get better efficiency than my epa wood insert as well. Never mind the work and expense (gas for instance) of cutting up and spliiting a log truck load. The moving of material around, here to there to there, etc, would be much less. The loads that have to be lifted, though, could be greater or equal with pellets, since you're handling 40 lb bags instead of splits (I try to lift the rounds as little as possible). At the end of their trail, each bag would also have to be lifted up to the hopper next to the boiler. This is neglecting a bulk storage, vacuum transport, etc.
Anyway, just thinking. Thanks.
Most of my buddies and myself use 4 tons give or take. I always like to finish a year with at least a "ton in the stash," just for mental comfort
Reactions: slvrblkk
Just over 3 here. cold years, 3.5. But, i keep my place much cooler than most at 66.
I am heating a basement of about 800 sqft and about 2700sqft of upstairs ranch with austroflamm integra, 5-7 tons per year for 18 years now.
Andy
Because you are not married , cheap, or an Eskimo?
useing a bag per day is a good way to figure out how many tons you need. my heating season is from oct 15-april 15. heating around 1400sft single story with avg insulation with house avg temp at 72. go threw 3-3.5 ton a year.
last year I burned 4.5 tons - this year probably closer to 5. That's with my stove running 24/7 in Maine. I heat 2000+ sq ft with my stove, which is a 43k btu unit.
im not married, but my gf does live with me. We are plenty comfortable at these temps. At night, we drop it back to 63. and we still wake up sweaty half the time.
i am cheap. but mostly because i'm poor. all my money goes to taxes it seems :P
i'm not an eskimo. i wish i was so i could try some seal tail and whale meat..... (i love crazy foods)
For the past 6 years I've burned 8-8.3 ton of pellets per year for heat keeping my 2100 sq. ft. house 70-72* plus DHW all year long ( yes in the non-heating months too). I averaged around 1000 gal of oil per year when I burned oil, keeping the house 66-68*.
Reactions: PoolGuyinCT
In NW NJ near the Delaware Water Gap..... 2000 sq ft 1876 Victorian.... 10 ft ceilings..... You get the idea..... 5 tons of pellets and 300 gal hho (for some occasional heat but mostly hot water).....
Roughly, how many tons would I expect to burn in a stove for a for a 7 year old (6") colonial of 2000 ft2 in the Northeast? Just trying to get a ballpark.
I have a 1900 square foot, 4" wall cape in upstate NY. When I had my Whitfield and QuadraFire I would use between 2-2 1/2 tons. Now that I changed stoves to an ultra efficient european model, I will be just over a ton. Hope this helps;)
Reactions: DexterDay
I have burned 147 bags so far my house is nice and warm 66 in basement 73 first and second story from my modified Englander pdv stove its really a furnace it has a filtered return from the second floor. I like this stove it has a great control board very adjustable.
Wow, that's great.
Average is 5 tons plus 50 gallons of oil. I have burned 6 tons, like two years ago. I would burn more if I could get my stove to take them. Any time 20 f or higher, no furnace assist. My wife wants the home temp up in the mid 70's. about 2200 sq ft.
We stay warmer with pellets than we would if we had to use just oil. Common theme around here.
3 tons house approx. 2,400 sq. ft. Shop 1 ton. I also gauge a bag a day for the house during the heating season.:cool:
Many good responses here about the amount of pellets.
I will chime in on the thought of a boiler. IMHO, good direction to look at. If I had it to do again, would have gone that route for even heating.
Reactions: jtakeman
Way too many variables to make a guess on what you will go through for the whole season.
4 ton is probably a good baseline to start with.
I burned 2 1/2 tons so far. I'm not in the northeast though. But I am heating 3k plus square feet.
I'm in the northeast and heating over 1800 square feet on two floors and you can see the variation in my signature. I'm getting ready to toss bag number 190 in the hopper for this season. It should be under 4.5 tons as things are warming up and I'll put the stove in on/off mode on the t-stat or it will be turned off for long periods of time like at the first part of the season.
Just 7 bags short of three tons of PA Pellets. Scored two tons of Summersets at Lowes today. Avrg. just under 4 tons a year. This year looking real good. 1900 square ft Cape built in the 30's.
I burnt 4.5 tons last year, and probably a little over this year - Maine at 2000+ sq ft.
2 bags everyday if it's below 38, 1.333 bags when its 40-45 and 1 bag low 50/s. Livingroom where stove is 73-77. all other first floor rooms 69-73. second floor rooms 66-68. even when its zero out.. a real windy 10 degree day stove works harder than a calm -4 night..
Southeastern PA. On pace to burn 4-4.5 tons. 3,300 sqft open floor plan new construction (2002). Keeps the main floor 68-69 and the master bedroom (furthest from the insert) around 66. Will use around 100-150 gallons of propane this winter which is mostly for hot water and minimal heat as the thermostats come up to temps before I get home. Last winter used about 1,000-1,200 gallons of propane.
Can't wait till this summer when I complete finishing my basement and add a freestanding stove down there...... Soon to be a Basement Dweller!!
