Shipper50 said:Webmaster said:Shipper, I really think you have to take a couple weeks with this thing. A block off at the bottom will definitely help. There is no magic bullet (like a PE) - we have members with PE's that cannot raise their house to the degree that you are trying to.
I'm not saying that you will be satisfied in the end, but it does not sound like the stove is falling far short. Perhaps the better block-off and some more time with it will raise your level of satisfaction and give you a longer time to consider exactly what action (if any) you want to take with the dealer.
Could you or anyone else tell me where to get this block off plate? What is another couple of $$$ when I have already spent thousands.
Also, If this block off plate allows me another 10 degrees in my house, drinks are on me as its never been more than 67 in the house with the insert running full air and wood.
Shipper
shipper, listen, you need to get block off plate
https://www.hearth.com/econtent/index.php/forums/viewthread/9630/P0/
and you cannot run the stove wide open for long periods of time... they are designed to work with less air at high temps......
if you have a high ceiling then ceiling fans will be a dramatic help
turn your heat on as log homes do take time to absorb heat turn your thermostat to 70 and run your stove maybe you can get the logs to absorb quicker
when your stove gets hot turn the air down you should see flames doing crazy stuff thtas when you know your secondary is burning = higher temp
it takes time to raise the temp in a house (most of the time) it will not got up 10 degrees over the entire house in 15-20 minutes most people go up a couple of degrees an hour
